An open microscopic model of heat conduction: evolution and non-equilibrium stationary states
Abstract : We consider a one-dimensional chain of coupled oscillators in contact at both ends with heat baths at different temperatures, and subject to an external force at one end. The Hamiltonian dynamics in the bulk is perturbed by random exchanges of the neighbouring momenta such that the energy is locally conserved. We prove that in the stationary state the energy and the volume stretch profiles, in large scale limit, converge to the solutions of a diffusive system with Dirichlet boundary conditions. As a consequence the macroscopic temperature stationary profile presents a maximum inside the chain higher than the thermostats temperatures, as well as the possibility of uphill diffusion (energy current against the temperature gradient). Finally, we are also able to derive the non-stationary macroscopic coupled diffusive equations followed by the energy and volume stretch profiles.
Document type :
Preprints, Working Papers, ...
Complete list of metadatas
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-02081200
Contributor : Marielle Simon <>
Submitted on : Monday, September 9, 2019 - 3:34:01 PM
Last modification on : Tuesday, September 10, 2019 - 1:24:09 AM
File
2019-08-corrections-ARXIV.pdf
Identifiers
  • HAL Id : hal-02081200, version 2
Collections
Citation
Tomasz Komorowski, Stefano Olla, Marielle Simon. An open microscopic model of heat conduction: evolution and non-equilibrium stationary states. 2019. ⟨hal-02081200v2⟩
Share
Metrics
Record views
17
Files downloads
138
