Coupler-curve synthesis of four-bar linkages via a novel formulation, Mechanism and Machine Theory, vol.94, pp.177-187, 2015. ,
On the optimum synthesis of a four-bar linkage using differential evolution and method of variable controlled deviations, Mechanism and Machine Theory, vol.44, pp.235-246, 2009. ,
Optimal synthesis of mechanisms with genetic algorithms, Mechanism and Machine Theory, vol.37, pp.1165-1177, 2002. ,
Circuits and branches of single-degree-of-freedom planar linkages, Journal of Mechanical Design-Transactions of the ASME, vol.115, issue.2, pp.223-230, 1993. ,
Mechanical error of a four-bar linkage coupler curve, Mechanism and Machine Theory, vol.22, pp.85-88, 1987. ,
Four-bar linkage synthesis using non-convex optimization, pp.618-635, 2016. ,
Kinematic geometry of mechanisms, Oxford engineering science series, 1978. ,
, Functional analysis and applied mathematics, NBS report, 1952.
Newton-algorithmen zur bestimmung von nullstellen mit fehlerschranken, Computing, vol.4, issue.3, pp.187-201, 1969. ,
, Geometric design of linkages, 2010.
Smart devices and machines for advanced manufacturing, ch. Appropriate Design of Parallel Manipulators, pp.1-25, 2008. ,
On three-bar motion in plane space, Proceedings of the London Mathematical Society, issue.1, pp.14-23 ,
Kinematic mapping based assembly mode evaluation of planar four-bar mechanisms, Journal of Mechanical Design, vol.129, issue.9, pp.924-929, 2006. ,
Complete solution of the ninepoint path synthesis problem for four-bar linkages, Journal of Mechanical DesignTransactions of the ASME, vol.114, issue.1, pp.153-159, 1992. ,
