Towards action-refinement in process algebras, LICS, pp.138-145, 1989. ,
The connection between an event structure semantics and an operational semantics for TCSP, Acta Informatica, vol.31, issue.1, pp.81-104, 1994. ,
Domains and event structures for fusions, LICS, pp.1-12, 2017. ,
DOI : 10.1109/lics.2017.8005135
URL : http://arxiv.org/pdf/1701.02394
Categories of Asynchronous Systems, 1988. ,
A fully abstract semantics for causality in the ?-calculus, Acta Informatica, vol.35, issue.5, pp.353-400, 1998. ,
On the semantics of concurrency: partial orders and transition systems, LNCS, vol.249, pp.123-137, 1987. ,
URL : https://hal.archives-ouvertes.fr/inria-00076004
Permutation of transitions: an event structure semantics for CCS and SCCS, REX: Linear Time, Branching Time and Partial Order in Logics and Models for Concurrency, vol.354, pp.411-427, 1988. ,
Flow models of distributed computations: event structures and nets, INRIA, 1991. ,
URL : https://hal.archives-ouvertes.fr/inria-00075080
Flow models of distributed computations: three equivalent semantics for CCS. Information and Computation, vol.114, pp.247-314, 1994. ,
URL : https://hal.archives-ouvertes.fr/inria-00075078
A theory of communicating sequential processes, Journal of ACM, vol.31, issue.3, pp.560-599, 1984. ,
Event structure semantics for nominal calculi, LNCS, vol.4137, pp.295-309, 2006. ,
Session types as intuitionistic linear propositions, LNCS, vol.6269, pp.222-236, 2010. ,
Models for name-passing processes: interleaving and causal. Information and Computation, vol.190, pp.136-178, 2004. ,
Compositional event structure semantics for the internal ?-calculus, LNCS, vol.4703, pp.317-332, 2007. ,
Event structure semantics of parallel extrusion in the ?-calculus, LNCS, vol.7213, pp.225-239, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00687502
Operational and denotational semantics for the reversible ?-calculus, 2015. ,
Rigid families for CCS and the ?-calculus, LNCS, vol.9399, pp.223-240, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01189062
Rigid families for the reversible ?-calculus, Reversible Computation, vol.9720, pp.3-19, 2016. ,
Refinement of actions in event structures and causal trees, Theoretical Computer Science, vol.118, issue.1, pp.21-48, 1993. ,
On the consistency of truly concurrent operational and denotational semantics, 1988. ,
A partial ordering semantics for CCS, Theoretical Computer Science, vol.75, issue.3, pp.223-262, 1990. ,
Concurrent histories: A basis for observing distributed systems, Journal of Computer and System Sciences, vol.34, issue.2/3, pp.422-461, 1987. ,
Non-interleaving semantics for mobile processes, Theoretical Computer Science, vol.216, issue.1-2, pp.237-270, 1999. ,
Multiparty session types meet communicating automata, LNCS, vol.7211, pp.194-213, 2012. ,
Comparing syntactic and semantic action refinement. Information and Computation, vol.125, pp.118-143, 1996. ,
Towards a categorical representation of reversible event structures, EPTCS, vol.246, pp.49-60, 2017. ,
Event structure semantics of (controlled) reversible CCS, Reversible Computation, vol.11106, pp.122-102, 2018. ,
Language primitives and type discipline for structured communication-based programming, LNCS, vol.1381, pp.122-138, 1998. ,
Multiparty asynchronous session types, POPL, pp.273-284, 2008. ,
Multiparty asynchronous session types, Journal of ACM, vol.63, issue.1, p.67, 2016. ,
Causality and true concurrency: A data-flow analysis of the ?-calculus (extended abstract), LNCS, vol.936, pp.277-291, 1995. ,
Quantitative and qualitative extensions of event structures, 1996. ,
From communicating machines to graphical choreographies, POPL, pp.221-232, 2015. ,
Bundle event structures: a non-interleaving semantics for LOTOS, Formal Description Techniques for Distributed Systems and Communication Protocols, pp.331-346, 1993. ,
Modelling nondeterministic concurrent processes with event structures, Fundamenta Informaticae, vol.14, issue.1, pp.39-74, 1991. ,
A Calculus of Communicating Systems, LNCS. Springer, vol.92, 1980. ,
Concurrent semantics for the ?-calculus, vol.1, pp.411-429, 1995. ,
Petri nets, event structures and domains, part I, Theoretical Computer Science, vol.13, issue.1, pp.85-108, 1981. ,
TCSP: theory of communicating sequential processes, Advances in Petri Nets, vol.255, pp.441-465, 1986. ,
Reversibility and asymmetric conflict in event structures, Journal of Logical and Algebraic Methods in Programming, vol.84, issue.6, pp.781-805, 2015. ,
Types and Programming Languages, 2002. ,
An interaction-based language and its typing system, LNCS, vol.817, pp.122-138, 1994. ,
Dependent session types via intuitionistic linear type theory, PPDP, pp.161-172, 2011. ,
Well-behaved flow event structures for parallel composition and action refinement, Theoretical Computer Science, vol.311, issue.1-3, pp.463-478, 2004. ,
Typed event structures and the linear ?-calculus, Theoretical Computer Science, vol.411, issue.19, pp.1949-1973, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00496903
Propositions as sessions, Journal of Functional Programming, vol.24, issue.2-3, pp.384-418, 2014. ,
Events in Computation, 1980. ,
Event structure semantics for CCS and related languages, LNCS, vol.140, pp.561-576, 1982. ,
An introduction to event structures, REX: Linear Time, Branching Time and Partial Order in Logics and Models for Concurrency, vol.354, pp.364-397, 1988. ,
, Note that the mapping p?q ? [?] ? is undefined whenever either [?] ? = {p?q} or one of p, q occurs in ?, but p?q is not their first communication. Proposition A.5 1. If ? ? ? is defined
, From the fact that in any communication sequence ? 1 and ? 2 can be swapped
, Otherwise either ? = [?] ? , in which case we are done, or one of p, q occurs in ?, but ? is not their first communication. We show that this last case is impossible. In fact if one of p, q occurs in ?, then one of p, q occurs in ? ? ?, If ? ? ? is defined by Point 4 ? ? ? < ? ? (? ? ? ) and by Point 2 ? ? (? ? ? ) = ?
G 2 and [p?q] ? ? GE(G i ) for either i = 1 or i = 2 ,
, where in the second case [p?q] ? ? GE(G i ) for all i ? I holds by definition of projection
