An immersed boundary method using unstructured anisotropic mesh adaptation combined with level-sets and penalization techniques, Journal of Computational Physics, vol.257, pp.83-101, 2014. ,
DOI : 10.1016/j.jcp.2013.08.052
URL : https://hal.archives-ouvertes.fr/hal-00786853
The design and application of upwind schemes on unstructured meshes, 27th Aerospace sciences meeting, p.366, 1989. ,
A new ALE adaptive unstructured methodology for the simulation of moving bodies, 32nd Aerospace Sciences Meeting and Exhibit, p.414, 1994. ,
A simple and fast phase transition relaxation solver for compressible multicomponent two-phase flows, Computers and Fluids, vol.150, pp.31-45, 2017. ,
DOI : 10.1016/j.compfluid.2017.03.022
URL : https://hal.archives-ouvertes.fr/hal-01502389
A simple phase transition relaxation solver for liquidvapor flows, International Journal for Numerical Methods in Fluids, vol.83, issue.7, pp.583-605, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01359203
Sharpening diffuse interfaces with compressible fluids on unstructured meshes, Journal of Computational Physics, vol.340, pp.389-417, 2017. ,
DOI : 10.1016/j.jcp.2017.03.042
URL : https://hal.archives-ouvertes.fr/hal-01455167
Modelling detonation waves in heterogeneous energetic materials, Journal of Computational Physics, vol.196, issue.2, pp.490-538, 2004. ,
DOI : 10.1016/j.jcp.2003.11.015
A higher-order generalized ghost fluid method for the poor for the three-dimensional two-phase flow computation of underwater implosions, Journal of Computational Physics, vol.227, issue.16, pp.7674-7700, 2008. ,
FIVER: A finite volume method based on exact two-phase Riemann problems and sparse grids for multi-material flows with large density jumps, Journal of Computational Physics, vol.231, issue.19, pp.6360-6379, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00703493
A non-oscillatory Eulerian approach to interfaces in multimaterial flows (the Ghost Fluid Method), Journal of Computational Physics, vol.152, issue.2, pp.457-492, 1999. ,
Three-dimensional front tracking, SIAM Journal of Scientific Computing, vol.19, pp.703-730, 1998. ,
DOI : 10.1137/s1064827595293600
Towards the direct numerical simulation of nucleate boiling flows, International Journal of Multiphase Flow, vol.66, pp.62-78, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01313339
Élaboration des lois d'état d'un liquide et de sa vapeur pour les modèles d'écoulements diphasiques, International journal of thermal sciences, vol.43, issue.3, pp.265-276, 2004. ,
The Noble-Abel stiffened-gas equation of state, Physics of Fluids, vol.28, issue.4, p.46102, 2016. ,
Ghost fluid method for strong shock impacting on material interface, Journal of Computational Physics, vol.190, issue.2, pp.651-681, 2003. ,
DOI : 10.1016/s0021-9991(03)00301-2
The modified ghost fluid method as applied to extreme fluidstructure interaction in the presence of cavitation, Communications in Computational Physics, vol.1, issue.5, pp.898-919, 2006. ,
Numerical simulation of fluid-structure interaction using modified ghost fluid method and Naviers equations, Journal of Scientific Computing, vol.36, issue.1, pp.45-68, 2008. ,
Godunov type method on non-structured meshes for threedimensional moving boundary problems, Computer methods in applied mechanics and engineering, vol.113, issue.1-2, pp.183-204, 1994. ,
URL : https://hal.archives-ouvertes.fr/inria-00074789
On the conservative and accurate CFD approximations for moving meshes and moving boundaries, Computer methods in applied mechanics and engineering, vol.190, pp.1801-1825, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-01313354
A conservative level set method for two phase flow II, Journal of Computational Physics, vol.225, pp.785-807, 2007. ,
A general formulation for cavitating, boiling and evaporating flows, Computers & Fluids, vol.128, pp.53-64, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01277179
An interface capturing method for the simulation of multi-phase compressible flows, J. Comput. Phys, vol.229, pp.7411-7450, 2010. ,
High resolution schemes using flux limiters for hyperbolic conservation laws, SIAM Journal on Numerical Analysis, vol.21, issue.5, pp.995-1011, 1984. ,
Restoration of the contact surface in the HLLRiemann solver, Shock waves, vol.4, issue.1, pp.25-34, 1994. ,
Towards the ultimate conservative difference scheme. V. A second-order sequel to Godunov's method, Journal of Computational Physics, vol.32, issue.1, pp.101-136, 1979. ,
A real ghost fluid method for the simulation of multimedium compressible flow, SIAM Journal on Scientific Computing, vol.28, issue.1, pp.278-302, 2006. ,
Algorithms for interface treatment and load computation in embedded boundary methods for fluid and fluid-structure interaction problems, International Journal for Numerical Methods in Fluids, vol.67, issue.9, pp.1175-1206, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00651118
An interface tracking method for a 3D Eulerian hydrodynamics code, Atomic Weapons Research Establishment (AWRE) Technical Report, p.35, 1930. ,
Fully multidimensional flux-corrected transport algorithms for fluids, Journal of Computational Physics, vol.31, issue.3, pp.335-362, 1979. ,
A systematic approach for constructing higher-order immersed boundary and ghost fluid methods for fluid-structure interaction problems, Journal of Computational Physics, vol.231, issue.7, pp.2892-2923, 2012. ,
