Robustness of linear time-varying systems with relaxed excitation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Adaptive Control and Signal Processing Année : 2019
It is a well-known fact that linear time-varying systems with a persistently excited state matrix are exponentially converging and input-to-state stable with respect to additive perturbations. Recently, several relaxed conditions of persistent excitation have been presented [1], [2], which ensure an asymptotic convergence rate in the system. In the present work it is shown that these conditions are similar, and that under such a relaxed excitation only non-uniform in time input-to-state stability and integral input-to-state stability properties can be obtained. The results are illustrated by simulations for a problem of estimation in the linear regression model.
Relaxed_PE_ISS_new.pdf (469.49 Ko) Télécharger le fichier
hal-02082769 , version 1 (28-03-2019)
Denis Efimov, Nikita Barabanov, Romeo Ortega. Robustness of linear time-varying systems with relaxed excitation. International Journal of Adaptive Control and Signal Processing, 2019, ⟨10.1002/acs.2997⟩. ⟨hal-02082769⟩
148 Consultations
281 Téléchargements
