The significance of reducing setup times/setup costs, European Journal of Operational Research, vol.187, issue.3, pp.978-984, 2008. ,
A survey of scheduling problems with setup times or costs, European Journal of Operational Research, vol.187, issue.3, pp.985-1032, 2008. ,
Mapping pipeline skeletons onto heterogeneous platforms, J Parallel and Distributed Computing, vol.68, issue.6, pp.790-808, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00118921
Throughput optimization for pipeline workflow scheduling with setup times, Proceedings of CGWS 2012, the CoreGRID/ERCIM Workshop on Grids, Clouds and P2P Computing, in conjunction with EuroPar, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00763362
Scheduling flowshops with finite buffers and sequence-dependent setup times, 1999. ,
, Comp & Indus Engineering, vol.36, issue.1, pp.163-177
Ordering pipelined query operators with precedence constraints, 2005. ,
Exploiting throughput for pipeline execution in streaming image processing applications, Proceedings of the 12th international conference on Parallel Processing, pp.1095-1105, 2006. ,
Investigating the use of gpuaccelerated nodes for sar image formation, CLUS-TER, pp.1-8, 2009. ,
Job shop scheduling with group-dependent setups, finite buffers, and long time horizon, Annals of Operations Research, vol.76, pp.233-259, 1998. ,
DOI : 10.1109/cdc.1995.478801
Color image processing pipeline. Signal Processing Magazine, IEEE, vol.22, issue.1, pp.34-43, 2005. ,
DOI : 10.1109/msp.2005.1407713
Elastic scaling of data parallel operators in stream processing, Proceedings of the 2009 IEEE International Symposium on Parallel&Distributed Processing, pp.1-12, 2009. ,
Optimal mapping of sequences of data parallel tasks, ACM SIGPLAN Notices, vol.30, issue.8, pp.134-143, 1995. ,
Optimal latencythroughput tradeoffs for data parallel pipelines, Proceedings of the eighth annual ACM symposium on Parallel algorithms and architectures, p.71, 1996. ,
DOI : 10.1145/237502.237508
