Coscheduling algorithms for high-throughput workload execution, Journal of Scheduling, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01252366
Resilient application co-scheduling with processor redistribution ,
URL : https://hal.archives-ouvertes.fr/hal-01354863
An approach to resource-aware coscheduling for CMPs, Proc. 24th ACM Int. Conf. on Supercomputing ICS '10, 2010. ,
Efficient collective communication in distributed heterogeneous systems, Journal of Parallel and Distributed Computing, vol.63, issue.3, pp.251-263, 2003. ,
Approximation algorithms for scheduling independent malleable tasks, Parallel Processing, vol.2150, pp.191-197, 2001. ,
Graph theory with applications, 1976. ,
Unified model for assessing checkpointing protocols at extreme-scale, Concurrency and Computation: Practice and Experience, vol.26, issue.17, pp.2772-2791, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00696154
Checkpointing strategies for parallel jobs, High Performance Computing, Networking, Storage and Analysis (SC), 2011 International Conference for, pp.1-11, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00560582
Scheduling a batching machine, J. Scheduling, vol.1, pp.31-54, 1998. ,
Predicting inter-thread cache contention on a chip multi-processor architecture, HPCA 11, pp.340-351, 2005. ,
Performance bounds for level-oriented two-dimensional packing algorithms, SIAM Journal on Computing, vol.9, issue.4, pp.808-826, 1980. ,
Introduction to Algorithms, 2009. ,
A higher order estimate of the optimum checkpoint interval for restart dumps, FGCS, vol.22, issue.3, pp.303-312, 2004. ,
Optimal control of batch service queues, Advances in Applied Probability, pp.340-361, 1973. ,
Performance and reliability trade-offs for the double checkpointing algorithm, International Journal of Networking and Computing, vol.4, issue.1, pp.23-41, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01091928
Scheduling parallel tasks: Approximation algorithms. Handbook of Scheduling: Algorithms, Models, and Performance Analysis, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00003126
A survey of rollback-recovery protocols in message-passing systems, ACM Comput. Surv, vol.34, issue.3, pp.375-408, 2002. ,
Detection and correction of silent data corruption for large-scale high-performance computing, Proceedings of the International Conference on High Performance Computing, Networking, Storage and Analysis, SC '12, vol.78, pp.1-78, 2012. ,
Adaptive parallel job scheduling with flexible coscheduling, IEEE. Trans. Parallel Distributed Systems, vol.16, issue.11, pp.1066-1077, 2005. ,
The Implementation of the Cilk-5 Multithreaded Language, Proceedings of the ACM SIGPLAN 1998 Conference on Programming Language Design and Implementation, PLDI '98, pp.212-223, 1998. ,
Reducing the energy cost of computing through efficient co-scheduling of parallel workloads, Design, Automation Test in Europe Conference Exhibition (DATE), pp.994-999, 2012. ,
Fault-Tolerance Techniques for HighPerformance Computing, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01200488
Improving Performance via Mini-applications, Research Report, vol.5574, 2009. ,
Efficient scheduling algorithms for a single batch processing machine, Operations Research Letters, vol.5, issue.2, pp.61-65, 1986. ,
Optimal batch schedules for parallel machines, Proceedings of the 13th Annual Algorithms and Data Structures Symposium, 2013. ,
A stochastic batching and scheduling problem, Probability in the Engineering and Informational Sciences, vol.15, issue.04, pp.465-479, 2001. ,
Power-aware MPI task aggregation prediction for high-end computing systems, IPDPS 10, pp.1-12, 2010. ,
Batch resizing policies and techniques for fine-grain grid tasks: The nuts and bolts, J. Information Processing Systems, vol.7, issue.2, 2011. ,
Hiding Checkpoint Overhead in HPC Applications with a Semi-Blocking Algorithm, Cluster Computing (CLUSTER), 2012 IEEE International Conference on, pp.364-372, 2012. ,
Scheduling with batching: a review, European Journal of Operational Research, vol.120, issue.2, pp.228-249, 2000. ,
Speedup-aware co-schedules for efficient workload management, Parallel Processing Letters, vol.23, issue.2, 2013. ,
A first order approximation to the optimum checkpoint interval, Comm. of the ACM, vol.17, issue.9, pp.530-531, 1974. ,
