HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Optimal Checkpointing Period with Replicated Execution on Heterogeneous Platforms
Abstract : In this paper, we design and analyze strategies to replicate the execution of an application on two diierent platforms subject to failures, using checkpointing on a shared stable storage. We derive the optimal paaern size W for a periodic checkpointing strategy where both platforms concurrently try and executeW units of work before checkpointing. e rst platform that completes its paaern takes a checkpoint, and the other platform interrupts its execution to synchronize from that checkpoint. We compare this strategy to a simpler on-failure checkpointing strategy, where a checkpoint is taken by one platform only whenever the other platform encounters a failure. We use rst or second-order approximations to compute overheads and optimal paaern sizes, and show through extensive simulations that these models are very accurate. e simulations show the usefulness of a secondary platform to reduce execution time, even when the platforms have relatively diierent speeds: in average, over a wide range of scenarios, the overhead is reduced by 30%. e simulations also demonstrate that the periodic checkpointing strategy is globally more eecient, unless platform speeds are quite close.
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-02082847
Contributor : Equipe Roma Connect in order to contact the contributor
Submitted on : Thursday, March 28, 2019 - 2:59:01 PM
Last modification on : Monday, May 16, 2022 - 4:46:02 PM
Long-term archiving on: : Saturday, June 29, 2019 - 2:31:29 PM
File
replication.pdf
Identifiers
Collections
Citation
Anne Benoit, Aurélien Cavelan, Valentin Le Fèvre, Yves Robert. Optimal Checkpointing Period with Replicated Execution on Heterogeneous Platforms. 2017 Workshop on Fault-Tolerance for HPC at Extreme Scale FTXS, Jun 2017, Washington, United States. pp.9-16, ⟨10.1145/3086157.3086165⟩. ⟨hal-02082847⟩
Share
Metrics
Record views
23
Files downloads
94
