Abstract : Over the last decade, sociomateriality appeared as a theme in IS research that has been interrogated with a variety of theoretical lenses. However, researchers have since raised methodological concerns regarding its application. This paper argues that a research methodology cannot be separated from either the theoretical lens that the research adopts or from its overarching purpose. Considering the broad range of theoretical lenses through which sociomateriality could be examined, this paper focuses on Barad’s theory of agential realism [25]. The paper provides a brief history of agential realism to shed light on the reasons behind IS researchers methodological difficulty and offers a diffraction methodology as a possible methodological guide to IS research adopting this lens. Implication for research is discussed.
https://hal.inria.fr/hal-02083585 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, March 29, 2019 - 10:20:19 AM Last modification on : Saturday, March 30, 2019 - 2:02:25 AM Long-term archiving on: : Sunday, June 30, 2019 - 1:28:25 PM
Amany Elbanna. Making a Difference in ICT Research: Feminist Theorization of Sociomateriality and the Diffraction Methodology. Working Conference on Information Systems and Organizations (IS&O), Dec 2018, San Francisco, CA, United States. pp.140-155, ⟨10.1007/978-3-030-04091-8_11⟩. ⟨hal-02083585⟩
