Hardware support for UNUM floating point arithmetic, Ph.D. Research in Microelectronics and Electronics. 93-96, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01618698
CADAC: A ControlledPrecision Decimal Arithmetic Unit, IEEE Trans. Comput. C, vol.32, pp.370-377, 1983. ,
The Rocket Chip Generator, 2016. ,
MPFR: A Multipleprecision Binary Floating-point Library with Correct Rounding, ACM Trans. Math. Softw, vol.33, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00070266
An 826 MOPS, 210uW/MHz Unum ALU in 65 nm, International Symposium on Circuits and Systems. 1-5, 2018. ,
, GNU MP: The GNU Multiple Precision Arithmetic Library, 2012.
The End of Error: Unum Computing, 2015. ,
Tackling Gaps in Floating-Point Arithmetic: Unum Arithmetic Implementation on FPGA, High Performance Computing and Communications, pp.615-616, 2017. ,
Specifications for a variable-precision arithmetic coprocessor, Proceedings 10th IEEE Symposium on Computer Arithmetic. 127-131, 1991. ,
, IEEE Standard for Floating-Point Arithmetic, IEEE, vol.60559, p.754, 2011.
Computer arithmetic and validity: Theory, implementation, and applications, 2013. ,
, The RoCC Doc V2: An Introduction to the Rocket Custom Coprocessor Interface
A family of variableprecision interval arithmetic processors, IEEE Trans. Comput, vol.49, issue.5, pp.387-397, 2000. ,
