An Experimental Study of the Treewidth of Real-World Graph Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Treewidth is a parameter that measures how tree-like a relational instance is, and whether it can reasonably be decomposed into a tree. Many computation tasks are known to be tractable on databases of small treewidth, but computing the treewidth of a given instance is intractable. This article is the first large-scale experimental study of treewidth and tree decompositions of real-world database instances (25 datasets from 8 different domains, with sizes ranging from a few thousand to a few million vertices). The goal is to determine which data, if any, can benefit of the wealth of algorithms for databases of small treewidth. For each dataset, we obtain upper and lower bound estimations of their treewidth, and study the properties of their tree decompositions. We show in particular that, even when treewidth is high, using partial tree decompositions can result in data structures that can assist algorithms.
LIPIcs-ICDT-2019-12.pdf (757.45 Ko) Télécharger le fichier
hal-02087763 , version 1 (02-04-2019)
Silviu Maniu, Pierre Senellart, Suraj Jog. An Experimental Study of the Treewidth of Real-World Graph Data. ICDT 2019 – 22nd International Conference on Database Theory, Mar 2019, Lisbon, Portugal. pp.18, ⟨10.4230/LIPIcs.ICDT.2019.12⟩. ⟨hal-02087763⟩
150 Consultations
61 Téléchargements
