, Acoustic Array Systems: Theory, Implementation, and Applications, pp.1-498, 2013.
Source identification system based on the timedomain nearfield equivalence source imaging: Fundamental theory and implementation, J. Sound Vib, vol.307, pp.202-225, 2007. ,
Real-time near-field acoustic holography for continuously visualizing nonstationary acoustic fields, J. Acoust. Soc. Am, vol.128, pp.3554-3567, 2010. ,
Time domain acoustical holography and its applications, vol.35, pp.16-25, 2001. ,
Resolution of the space/time inverse problem in near field acoustical holography: Application to the radiation of non stationary industrial sources, 2001. ,
FIG. 10. (Color online) Backpropagated RMS fields when two sources of interest whose signals are frequency limited to, Rep. Prog. Phys, vol.63, pp.1933-1995, 2000. ,
, Double-layer sonic time reversal imaging, vol.137, 2015.
Super-resolution imaging of sound sources in free field using a numerical time-reversal sink, Acta Acust. Acust, vol.95, pp.595-606, 2009. ,
Experimental localization of an acoustic sound source in a wind-tunnel flow by using a numerical timereversal technique, J. Acoust. Soc. Am, vol.132, issue.4, pp.2397-2407, 2012. ,
Self focusing in inhomogeneous media with time reversal acoustic mirrors, IEEE 1989 Proc. Ultrasonics Symposium, vol.2, pp.681-686, 1989. ,
Damage detection in composite plates by using an enhanced time reversal method, J. Aerosp. Eng, vol.20, issue.3, pp.141-151, 2007. ,
Experimental implementation of reverse time migration for nondestructive evaluation applications, J. Acoust. Soc. Am, vol.129, issue.1, pp.8-14, 2011. ,
Time-reversal in an ultrasonic waveguide, Appl. Phys. Lett, vol.70, issue.14, pp.1811-1813, 1997. ,
Phase conjugation in the ocean: Experimental demonstration of an acoustic time-reversal mirror, J. Acoust. Soc. Am, vol.103, issue.1, pp.25-40, 1998. ,
Sound focusing in rooms: The timereversal approach, J. Acoust. Soc. Am, vol.113, pp.1533-1543, 2003. ,
Subwavelength sound focusing using a time-reversal acoustic sink, Acta Acust. Acust, vol.93, pp.706-715, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-02095752
Near-field time-reversal amplification, J. Acoust. Soc. Am, vol.121, issue.6, pp.3602-3606, 2007. ,
Time reversal of noise sources in a reverberation room, J. Acoust. Soc. Am, vol.117, pp.2866-2872, 2005. ,
Time-reversal of ultrasonic fields. Part III: Theory of the closed time-reversal cavity, IEEE Trans. Ultrason., Ferroelectr., Freq. Control, vol.39, issue.5, pp.579-592, 1992. ,
On time reversal mirrors, Inverse Probl, vol.25, issue.9, p.95010, 2009. ,
Overcoming the diffraction limit in wave physics using a time-reversal mirror and a novel acoustic sink, Phys. Rev. Lett, vol.89, p.124301, 2002. ,
Time reversal in changing environments, Multiscale Model. Simul, vol.2, issue.4, pp.639-661, 2004. ,
Models, measurement and evaluation, Speech Dereverberation, pp.21-54, 2010. ,
Spherical expansions of time-domain acoustic fields: Application to near-field scanning, J. Acoust. Soc. Am, vol.98, issue.2, pp.1204-1215, 1995. ,
Evaluation of a separation method for source identification in small spaces, J. Acoust. Soc. Am, vol.134, pp.323-331, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-02088176
Time reversal of ultrasonic fields. Part I: Basic principles, IEEE Trans. Ultrason., Ferroelectr., Freq. Control, vol.39, pp.555-566, 1992. ,
On a novel application of the Helmholtz integral in the development of a virtual sonar, J. Acoust. Soc. Am, vol.108, issue.6, pp.2823-2828, 2000. ,
Statistically optimized near field acoustic holography using an array of pressure-velocity probes, J. Acoust. Soc. Am, vol.121, issue.3, pp.1550-1558, 2007. ,
Regularization methods for the acoustic inverse problem. Applications to the source identification in a confined and perturbed medium, 1997. ,
Identification of source velocities on 3D structures in non-anechoic environments: Theoretical background and experimental validation of the inverse patch transfer functions method, J. Sound Vib, vol.329, issue.18, pp.3691-3708, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01668973
Sound field separation with sound pressure and particle velocity measurements, J. Acoust. Soc. Am, vol.132, issue.6, pp.3818-3825, 2012. ,
DOI : 10.1121/1.4763988
URL : https://hal.archives-ouvertes.fr/hal-00768594
Real-time separation of nonstationary sound fields with pressure and particle acceleration measurements, J. Acoust. Soc. Am, vol.135, issue.6, pp.3474-3482, 2014. ,
DOI : 10.1121/1.4875576
Comparison of four subwoofer measurement techniques, J. Audio Eng. Soc, vol.55, issue.12, pp.1077-1091, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00206089
Evaluation of a method for the measurement of subwoofers in usual rooms, J. Acoust. Soc. Am, vol.127, pp.256-263, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00461606
, Fourier Acoustics: Sound Radiation and Nearfield Acoustical Holography, pp.245-249, 2009.
DOI : 10.1121/1.1289662
Appropriate Gaussian quadrature formulae for triangles, Int. J. Appl. Math. Comput, vol.4, issue.1, pp.23-38, 2012. ,
Values of the nodes and weights of quadrature formulas of Gauss-Markov type for a sphere from the ninth to seventeenth order of accuracy that are invariant with respect to an octahedron group with inversion, USSR Comp. Math. Math, vol.15, pp.48-54, 1975. ,
Time-reversal imaging with multiple signal classification considering multiple scattering between the targets, J. Acoust. Soc. Am, vol.115, pp.3042-3047, 2004. ,
Real time inverse filter focusing through iterative time reversal, J. Acous. Soc. Am, vol.115, issue.2, pp.768-775, 2004. ,
DOI : 10.1121/1.1636462
Experimentally identifying masked sources applying time reversal with the selective source reduction method, J. Appl. Phys, vol.105, issue.8, p.83506, 2009. ,
Highly resolved detection and selective focusing in a waveguide using the D.O.R.T. method, J. Acoust. Soc. Am, vol.105, pp.2634-2642, 1999. ,
Image method for efficiently simulating small-room acoustics, J. Acoust. Soc. Am, vol.65, issue.4, pp.943-950, 1979. ,
