Remove conditional "WANT" macros from numbered clauses proposal for C2x - Archive ouverte HAL Access content directly
Reports (Technical Report) Year : 2019
The recent integration of TS 18661-1 has moved the use of "WANT" macros into the main body of the C standard, making the added interfaces optional. We think that this is not optimal, neither for user code nor for implementations, an propose to change that to a set of more straight forward feature test macros for the version of the included headers. Along with that also a long list of names have been imposed to the standard. We propose some mild modifications to reduce the pain of the transition and keep C open for future directions.
n2359+appendix.pdf (874.19 Ko) Télécharger le fichier
Dates and versions
hal-02089861 , version 1 (04-04-2019)
Identifiers
  • HAL Id : hal-02089861 , version 1
Cite
Jens Gustedt. Remove conditional "WANT" macros from numbered clauses proposal for C2x. [Technical Report] N2359, ISO JTC1/SC22/WG14. 2019. ⟨hal-02089861⟩
41 View
48 Download
Share
