Multi-Pose Interactive Linkage Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2019
We introduce an interactive tool for novice users to design mechanical objects made of 2.5D linkages. Users simply draw the shape of the object and a few key poses of its multiple moving parts. Our approach automatically generates a one-degree-of-freedom linkage that connects the fixed and moving parts, such that the moving parts traverse all input poses in order without any collision with the fixed and other moving parts. In addition, our approach avoids common linkage defects and favors compact linkages and smooth motion trajectories. Finally, our system automatically generates the 3D geometry of the object and its links, allowing the rapid creation of a physical mockup of the designed object.
mechanical_design.pdf (3.2 Mo) Télécharger le fichier
hal-02091234 , version 1 (05-04-2019)
Gen Nishida, Adrien Bousseau, Daniel G. Aliaga. Multi-Pose Interactive Linkage Design. Computer Graphics Forum, 2019, Proceedings Eurographics, 38 (2), ⟨10.1111/cgf.13637⟩. ⟨hal-02091234⟩
99 Consultations
328 Téléchargements
