H. Abdi, Encyclopedia for research methods for the social sciences, vol.6, pp.792-795, 2003.
J. Ahrens, B. Geveci, and C. Law, Paraview: An end-user tool for large data visualization. The visualization handbook, vol.717, 2005.
S. Allassonnì-ere, S. Durrleman, and E. Kuhn, Bayesian mixed effect atlas estimation with a diffeomorphic deformation model, SIAM Journal on Imaging Science, vol.8, p.13671395, 2015.
S. Allassonnì-ere, E. Kuhn, and A. Trouvé, Construction of bayesian deformable models via a stochastic approximation algorithm: a convergence study, Bernoulli, vol.16, issue.3, pp.641-678, 2010.
B. B. Amor, H. Drira, S. Berretti, M. Daoudi, and A. Srivastava, 4-d facial expression recognition by learning geometric deformations, IEEE Trans. Cybernetics, vol.44, issue.12, pp.2443-2457, 2014.
URL : https://hal.archives-ouvertes.fr/hal-00949002
Y. F. Atchade, An adaptive version for the metropolis adjusted langevin algorithm with a truncated drift, Methodology and Computing in applied Probability, vol.8, issue.2, pp.235-254, 2006.
M. Banerjee, R. Chakraborty, E. Ofori, M. S. Okun, D. E. Viallancourt et al., A nonlinear regression technique for manifold valued data with applications to medical image analysis, Proceedings of the IEEE Conference on Computer Vision and Pattern Recognition, pp.4424-4432, 2016.
DOI : 10.1109/cvpr.2016.479
M. Beg, M. Miller, A. Trouvé, and L. Younes, Computing large deformation metric mappings via geodesic flows of diffeomorphisms, IJCV, vol.61, issue.2, pp.139-157, 2005.
DOI : 10.1023/b:visi.0000043755.93987.aa
A. Bône, O. Colliot, and S. Durrleman, Learning distributions of shape trajectories from longitudinal datasets: a hierarchical model on a manifold of diffeomorphisms, Proceedings of the IEEE Conference on Computer Vision and Pattern Recognition, pp.9271-9280, 2018.
R. Chakraborty, M. Banerjee, and B. C. Vemuri, Statistics on the space of trajectories for longitudinal data analysis, 2017 IEEE 14th International Symposium on, pp.999-1002, 2017.
B. Charlier, J. Feydy, J. A. Glaunès, and A. Trouvé, An efficient kernel product for automatic differentiation libraries, 2017.
N. Charon and A. Trouvé, The varifold representation of nonoriented shapes for diffeomorphic registration, SIAM Journal on Imaging Sciences, vol.6, issue.4, pp.2547-2580, 2013.
G. E. Christensen, R. D. Rabbitt, and M. I. Miller, Deformable templates using large deformation kinematics, IEEE transactions on image processing, vol.5, issue.10, pp.1435-1447, 1996.
DOI : 10.1109/83.536892
B. Delyon, M. Lavielle, and E. Moulines, Convergence of a stochastic approximation version of the em algorithm, Annals of statistics, pp.94-128, 1999.
A. P. Dempster, N. M. Laird, and D. B. Rubin, Maximum likelihood from incomplete data via the em algorithm, Journal of the royal statistical society. Series B (methodological), pp.1-38, 1977.
DOI : 10.1111/j.2517-6161.1977.tb01600.x
S. Durrleman, S. Allassonnì-ere, and S. Joshi, Sparse adaptive parameterization of variability in image ensembles, IJCV, vol.101, issue.1, pp.161-183, 2013.
URL : https://hal.archives-ouvertes.fr/hal-00817565
S. Durrleman, X. Pennec, A. Trouvé, J. Braga, G. Gerig et al., Toward a comprehensive framework for the spatiotemporal statistical analysis of longitudinal shape data, International Journal of Computer Vision, vol.103, issue.1, pp.22-59, 2013.
URL : https://hal.archives-ouvertes.fr/hal-00813825
S. Durrleman, M. Prastawa, N. Charon, J. R. Korenberg, S. Joshi et al., Morphometry of anatomical shape complexes with dense deformations and sparse parameters, NeuroImage, 2014.
DOI : 10.1016/j.neuroimage.2014.06.043
URL : https://hal.archives-ouvertes.fr/hal-01015771
T. Fang, X. Zhao, S. K. Shah, and I. A. Kakadiaris, 4d facial expression recognition, Computer Vision Workshops (ICCV Workshops, pp.1594-1601, 2011.
DOI : 10.1109/iccvw.2011.6130440
B. Fischl and A. M. Dale, Measuring the thickness of the human cerebral cortex from magnetic resonance images, Proceedings of the National Academy of Sciences, vol.97, issue.20, p.55, 2000.
B. Fischl, D. H. Salat, E. Busa, M. Albert, M. Dieterich et al., Whole brain segmentation: automated labeling of neuroanatomical structures in the human brain, Neuron, vol.33, issue.3, pp.341-355, 2002.
J. Fishbaugh, M. Prastawa, G. Gerig, and S. Durrleman, Geodesic regression of image and shape data for improved modeling of 4D trajectories, ISBI 2014 -11th International Symposium on Biomedical Imaging, pp.385-388, 2014.
URL : https://hal.archives-ouvertes.fr/hal-01108243
T. Fletcher, Geodesic regression and the theory of least squares on riemannian manifolds, IJCV, vol.105, issue.2, pp.171-185, 2013.
P. Gori, O. Colliot, L. Marrakchi-kacem, Y. Worbe, C. Poupon et al., A Bayesian Framework for Joint Morphometry of Surface and Curve meshes in Multi-Object Complexes, Medical Image Analysis, vol.35, pp.458-474, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01359423
J. Hinkle, P. Muralidharan, P. T. Fletcher, and S. Joshi, Polynomial Regression on Riemannian Manifolds, pp.1-14, 2012.
M. W. Hirsch, Differential topology, vol.33, 2012.
A. Hyvärinen, J. Karhunen, and E. Oja, Independent component analysis, vol.46, 2004.
B. Jian and B. C. Vemuri, Robust point set registration using gaussian mixture models, vol.33, pp.1633-1645, 2011.
S. C. Joshi and M. I. Miller, Landmark matching via large deformation diffeomorphisms, IEEE Transactions on Image Processing, vol.9, issue.8, pp.1357-1370, 2000.
D. G. Kendall, Shape manifolds, procrustean metrics, and complex projective spaces, Bulletin of the London Mathematical Society, vol.16, issue.2, pp.81-121, 1984.
H. J. Kim, N. Adluru, M. D. Collins, M. K. Chung, B. B. Bendlin et al., Multivariate general linear models (mglm) on riemannian manifolds with applications to statistical analysis of diffusion weighted images, Proceedings of the IEEE Conference on Computer Vision and Pattern Recognition, pp.2705-2712, 2014.
H. J. Kim, N. Adluru, H. Suri, B. C. Vemuri, S. C. Johnson et al., Riemannian nonlinear mixed effects models: Analyzing longitudinal deformations in neuroimaging, Proceedings of IEEE Conference on Computer Vision and Pattern Recognition (CVPR, 2017.
I. Koval, J. B. Schiratti, A. Routier, M. Bacci, O. Colliot et al., Statistical learning of spatiotemporal patterns from longitudinal manifoldvalued networks, International Conference on Medical Image Computing and Computer-Assisted Intervention, pp.451-459, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01540828
D. C. Liu and J. Nocedal, On the limited memory bfgs method for large scale optimization, Mathematical programming, vol.45, issue.1-3, pp.503-528, 1989.
M. Lorenzi, N. Ayache, G. Frisoni, and X. Pennec, 4D registration of serial brains MR images: a robust measure of changes applied to Alzheimer's disease, Spatio Temporal Image Analysis Workshop (STIA), 2010.
M. Lorenzi, N. Ayache, and X. Pennec, Schild's ladder for the parallel transport of deformations in time series of images, pp.463-474, 2011.
M. Louis, A. Bône, B. Charlier, and S. Durrleman, Parallel transport in shape analysis: a scalable numerical scheme, International Conference on Geometric Science of Information, pp.29-37, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01565478
M. Louis, B. Charlier, P. Jusselin, P. Susovan, and S. Durrleman, A fanning scheme for the parallel transport along geodesics on riemannian manifolds, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01560787
F. Manasse and C. W. Misner, Fermi normal coordinates and some basic concepts in differential geometry, Journal of mathematical physics, vol.4, issue.6, pp.735-745, 1963.
J. M. Marin, P. Pudlo, C. P. Robert, and R. J. Ryder, Approximate bayesian computational methods, Statistics and Computing, vol.22, issue.6, pp.1167-1180, 2012.
URL : https://hal.archives-ouvertes.fr/hal-00567240
M. I. Miller, A. Trouvé, and L. Younes, Geodesic shooting for computational anatomy, Journal of Mathematical Imaging and Vision, vol.24, issue.2, pp.209-228, 2006.
P. Muralidharan and P. T. Fletcher, Sasaki metrics for analysis of longitudinal data on manifolds, Computer Vision and Pattern Recognition (CVPR), 2012 IEEE Conference on, pp.1027-1034, 2012.
M. Niethammer, Y. Huang, and F. X. Vialard, Geodesic regression for image time-series, International Conference on Medical Image Computing and Computer-Assisted Intervention, pp.655-662, 2011.
X. Pennec, Intrinsic statistics on riemannian manifolds: Basic tools for geometric measurements, Journal of Mathematical Imaging and Vision, vol.25, issue.1, pp.127-154, 2006.
URL : https://hal.archives-ouvertes.fr/inria-00614994
X. Pennec, P. Fillard, and N. Ayache, A riemannian framework for tensor computing, International Journal of Computer Vision, vol.66, issue.1, pp.41-66, 2006.
URL : https://hal.archives-ouvertes.fr/inria-00070743
J. B. Schiratti, S. Allassonnì-ere, O. Colliot, and S. Durrleman, Learning spatiotemporal trajectories from manifold-valued longitudinal data, vol.28, pp.2404-2412, 2015.
URL : https://hal.archives-ouvertes.fr/hal-01245909
N. Singh, J. Hinkle, S. Joshi, and P. T. Fletcher, Hierarchical geodesic models in diffeomorphisms, IJCV, vol.117, issue.1, pp.70-92, 2016.
Y. Stern, Cognitive reserve and alzheimer disease, Alzheimer Disease & Associated Disorders, vol.20, issue.2, pp.112-117, 2006.
URL : https://hal.archives-ouvertes.fr/inserm-02055901
J. Su, S. Kurtek, E. Klassen, and A. Srivastava, Statistical analysis of trajectories on riemannian manifolds: bird migration, hurricane tracking and video surveillance, The Annals of Applied Statistics, vol.8, issue.1, pp.530-552, 2014.
J. Su, A. Srivastava, F. D. De-souza, and S. Sarkar, Rate-invariant analysis of trajectories on riemannian manifolds with application in visual speech recognition, Proceedings of the IEEE Conference on Computer Vision and Pattern Recognition, pp.620-627, 2014.
Y. Sun and L. Yin, Facial expression recognition based on 3d dynamic range model sequences, European Conference on Computer Vision, pp.58-71, 2008.
M. Vaillant and J. Glaunès, Surface matching via currents. In: Information processing in medical imaging, pp.1-5, 2005.
URL : https://hal.archives-ouvertes.fr/hal-00263652
M. W. Woolrich, S. Jbabdi, B. Patenaude, M. Chappell, S. Makni et al., Bayesian analysis of neuroimaging data in fsl, Neuroimage, vol.45, issue.1, pp.173-186, 2009.
L. Yin, X. Chen, Y. Sun, T. Worm, and M. Reale, A high-resolution 3d dynamic facial expression database, Automatic Face & Gesture Recognition, pp.1-6, 2008.
L. Younes, Jacobi fields in groups of diffeomorphisms and applications, Quarterly of Applied Mathematics, vol.65, issue.1, pp.113-134, 2007.
L. Younes, Shapes and Diffeomorphisms. Applied Mathematical Sciences, 2010.
M. Zhang and P. T. Fletcher, Finite-dimensional lie algebras for fast diffeomorphic image registration, International Conference on Information Processing in Medical Imaging, pp.249-260
. Springer, , 2015.
M. Zhang, N. Singh, and P. T. Fletcher, Bayesian estimation of regularization and atlas building in diffeomorphic image registration, In: IPMI, vol.23, pp.37-48, 2013.
