New interface
WebSmatch
Remi Coletta 1 Emmanuel Castanier 1 Patrick Valduriez 1
1 ZENITH - Scientific Data Management
LIRMM - Laboratoire d'Informatique de Robotique et de Microélectronique de Montpellier, CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : WebSmatch is a flexible, open environment for discovering and matching complex schemas from heterogeneous Web data sources. It provides three basic functions: (1) metadata extraction from data sources; (2) schema matching, (3) schema clustering to group similar schemas together. WebSmatch is delivered through Web services, to be used directly by data integrators or other tools with RIA clients. It is implemented in Java, delivered as Open Source Software (under LGPL). WebSmatch has been used by Data Publica and CIRAD to integrate public and private data sources.
Document type :
Software
Complete list of metadata
https://hal.inria.fr/hal-02092613
Contributor : Patrick Valduriez Connect in order to contact the contributor
Submitted on : Monday, April 8, 2019 - 11:56:00 AM
Last modification on : Friday, August 5, 2022 - 3:03:28 PM
Citation
Remi Coletta, Emmanuel Castanier, Patrick Valduriez. WebSmatch. 2014. ⟨hal-02092613⟩
Share
Metrics
Record views
71
