Formal Verification of a State-of-the-Art Integer Square Root - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present the automatic formal verification of a state-of-the-art algorithm from the GMP library that computes the square root of a 64-bit integer. Although it uses only integer operations, the best way to understand the program is to view it as a fixed-point arithmetic algorithm that implements Newton's method. The C code is short but intricate, involving magic constants and intentional arithmetic overflows. We have verified the algorithm using the Why3 tool and automated solvers such as Gappa.
main.pdf (175.91 Ko) Télécharger le fichier
hal-02092970 , version 1 (08-04-2019)
Guillaume Melquiond, Raphaël Rieu-Helft. Formal Verification of a State-of-the-Art Integer Square Root. ARITH-26 2019 - 26th IEEE 26th Symposium on Computer Arithmetic, Jun 2019, Kyoto, Japan. pp.183-186, ⟨10.1109/ARITH.2019.00041⟩. ⟨hal-02092970⟩
289 Consultations
334 Téléchargements
