Control-theoretic methods for cyberphysical security: Geometric principles for optimal cross-layer resilient control systems, IEEE Control Syst, vol.35, issue.1, pp.110-127, 2015. ,
Robust structural analysis and design of distributed control systems to prevent zero dynamics attacks, Proc. IEEE Conf. Decision Control (CDC, pp.1356-1361, 2017. ,
A graph-theoretic characterization of perfect attackability for secure design of distributed control systems, IEEE Trans. Control Netw. Syst, vol.4, issue.1, pp.60-70, 2017. ,
Structural and strongly structural input and state observability of linear network systems, IEEE Trans. Control Netw. Syst, vol.5, issue.4, pp.2062-2072, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01663175
Unbiased minimum-variance input and state estimation for linear discrete-time systems, Automatica, vol.43, issue.1, pp.111-116, 2007. ,
A unified filter for simultaneous input and state estimation of linear discrete-time stochastic systems, Automatica, vol.63, pp.321-329, 2016. ,
A secure control framework for resource-limited adversaries, Automatica, vol.51, pp.135-148, 2015. ,
Attack detection and identification in cyber-physical systems, IEEE Trans. Autom. Control, vol.58, issue.11, pp.2715-2729, 2013. ,
, A divide-and-conquer approach to distributed attack identification, Proc. IEEE Conf. Decision Control, pp.5801-5807, 2015.
Secure estimation and control for cyber-physical systems under adversarial attacks, IEEE Trans. Autom. Control, vol.59, issue.6, pp.1454-1467, 2014. ,
Event-triggered state observers for sparse sensor noise/attacks, IEEE Trans. Autom. Control, vol.61, issue.8, pp.2079-2091, 2016. ,
Dynamic state recovery for cyber-physical systems under switching location attacks, IEEE Trans. Control Netw. Syst, vol.4, issue.1, pp.14-22, 2017. ,
Secure state estimation against sparse sensor attacks with adaptive switching mechanism, IEEE Trans. Autom. Control, vol.63, issue.8, pp.2596-2603, 2018. ,
Linear systems with sparse inputs: Observability and input recovery, Proc. American Control Conf. (ACC), pp.5251-5257, 2015. ,
Compressed sensing, IEEE Trans. Inf. Theory, vol.52, pp.1289-1306, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00369486
An introduction to compressive sampling, IEEE Signal Process. Mag, vol.25, pp.21-30, 2008. ,
, A Mathematical Introduction to Compressive Sensing, 2013.
Dynamic compressive sensing of timevarying signals via approximate message passing, IEEE Trans. Signal Process, vol.61, issue.21, pp.5270-5284, 2013. ,
Discrete and continuoustime soft-thresholding for dynamic signal recovery, IEEE Trans. Signal Process, vol.63, issue.12, pp.3165-3176, 2015. ,
Dynamic filtering of time-varying sparse signals via 1 minimization, IEEE Trans. Signal Process, vol.64, issue.21, pp.5644-5656, 2016. ,
Online optimization in dynamic environments: a regret analysis for sparse problems, Proc. IEEE Conf. Decision Control (CDC), pp.7225-7230, 2018. ,
Kalman filtered compressed sensing, IEEE Int. Conf. on Image Processing (ICIP), pp.893-896, 2008. ,
Methods for sparse signal recovery using Kalman filtering with embedded pseudo-measurement norms and quasi-norms, IEEE Trans. Signal Process, vol.58, pp.2405-2409, 2010. ,
Dynamic iterative pursuit, IEEE Trans. Signal Process, vol.60, issue.9, pp.4967-4972, 2012. ,
Tracking target signal strengths on a grid using sparsity, EURASIP J. Adv. Signal Process, vol.2014, issue.1, p.7, 2014. ,
Delayed observers for linear systems with unknown inputs, IEEE Trans. Autom. Control, vol.52, issue.2, pp.334-339, 2007. ,
Just relax: convex programming methods for identifying sparse signals in noise, IEEE Trans. Inf. Theory, vol.52, issue.3, pp.1030-1051, 2006. ,
Regression shrinkage and selection via the lasso, J. Roy. Stat. Soc., Ser. B, vol.58, pp.267-288, 1996. ,
Sharp thresholds for high-dimensional and noisy sparsity recovery using 1 -constrained quadratic programming (Lasso), IEEE Trans. Inf. Theory, vol.55, issue.5, pp.2183-2202, 2009. ,
The lasso problem and uniqueness, Electronic Journal of Statistics, vol.7, pp.1456-1490, 2013. ,
Signal recovery from random measurements via orthogonal matching pursuit, IEEE Trans. Inf. Theory, vol.53, pp.4655-4666, 2007. ,
Distributed optimization and statistical learning via the alternating direction method of multipliers, Found. Trends Mach. Learn, vol.3, issue.1, pp.1-122, 2010. ,
Distributed ADMM for in-network reconstruction of sparse signals with innovations, IEEE Trans. Signal Inf. Process. Netw, vol.1, issue.4, pp.225-234, 2015. ,
GPUaccelerated algorithms for compressed signals recovery with application to astronomical imagery deblurring, Int. J. Remote Sens, vol.39, issue.7, pp.2043-2065, 2018. ,
Recovery of exact sparse representations in the presence of bounded noise, IEEE Trans. Inf. Theory, vol.51, issue.10, pp.3601-3608, 2005. ,
