Sharing is caring: a cooperation scheme for RPL network resilience and efficiency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The IPv6 Routing Protocol for Low-Power and Lossy Networks (RPL) builds a Direction Oriented Directed Acyclic Graph (DODAG) rooted at one node. This node may act as a border router to provide Internet connectivity to the members of the DODAG but such a situation creates a single point of failure. Upon border router failure, all nodes connected to the DODAG are affected as all ongoing communications are instantly broken and no new communications can be initiated. Moreover, nodes close to the border router should forward traffic from farther nodes in addition to their own, which may cause congestion and energy depletion inequality. In this article we specify a full solution to enable border router redundancy in RPL networks. To achieve this, we propose a mechanism leveraging cooperation between colocated RPL networks. It enables failover to maintain Internet connectivity and load balancing to improve the overall energy consumption and bandwidth. Our contribution has been implemented in Contiki OS and was evaluated through experiments performed on the FIT IoT-LAB testbed.
papier.pdf (417.05 Ko) Télécharger le fichier
hal-02095410 , version 1 (02-07-2019)
  • HAL Id : hal-02095410 , version 1
Brandon Foubert, Julien Montavont. Sharing is caring: a cooperation scheme for RPL network resilience and efficiency. ISCC 2019 - 24th Symposium on Computers and Communications, Jun 2019, Barcelona, Spain. ⟨hal-02095410⟩
314 Consultations
340 Téléchargements
