Application and Limitations of Endoscopy in Anthropological and Archaeological Research, The Anatomical Record, vol.298, pp.1125-1134, 2015. ,
Terrestrial laser scanner data processing, XXth ISPRS Congress Istanbul, 2004. ,
3: Wedge Displays as Cameras, SID Symposium Digest of Technical Papers, vol.72, issue.1, pp.1999-2002, 2006. ,
TOF laser scanner characterization for low-range applications, pp.6491-6491, 2007. ,
Structured Lighting, 2012. ,
Linear Pushbroom Cameras, IEEE Trans. Pattern Anal. Mach. Intell, vol.19, pp.963-975, 1997. ,
Architectural Photogrammetry: basic theory, procedures, tools, ISPRS Commission, vol.5, pp.1-2, 2002. ,
URL : https://hal.archives-ouvertes.fr/halshs-00263785
Image Alignment and Stitching: A Tutorial, vol.89, 2004. ,
Flat-panel display using tapered waveguide, 2003. ,
Flat panel display using projection within a wedge-shaped waveguide, Proceedings of the 20th International Display Research Conference, pp.292-295, 2000. ,
Image capture via a wedge light-guide with no margins, Optics express, vol.18, pp.8453-8458, 2010. ,
Wedge optics in flat panel displays, Proc. IEEE, vol.101, pp.45-60, 2013. ,
Image superresolution: The techniques, applications, and future, Signal Processing, vol.128, pp.389-408, 2016. ,
