Fast and Faithful Performance Prediction of MPI Applications: the HPL Case Study
Finely tuning MPI applications (number of processes, granularity, collective
operation algorithms, topology and process placement) is critical to obtain good performance on
supercomputers. With a rising cost of modern supercomputers, running parallel
applications at scale solely to optimize their performance is extremely
expensive. Having inexpensive but faithful predictions of expected performance
could be a great help for researchers and system administrators.
The methodology we propose captures the complexity of adaptive applications by
emulating the MPI code while skipping insignificant parts. We demonstrate its
capability with High Performance Linpack (HPL), the benchmark used to rank
supercomputers in the TOP500 and which requires a careful tuning. We explain
(1) how we both extended the SimGrid's SMPI simulator and slightly modified the
open-source version of HPL to allow a fast emulation on a single commodity
server at the scale of a supercomputer and (2) how to model the different
components (network, BLAS, ...) of the system. We show that a careful
modeling of both spatial and temporal node variability allows us to obtain
predictions within a few percents of real experiments (see Figure 1).
paper.pdf (996.47 Ko)
Télécharger le fichier
slides.pdf (2.83 Mo)
Format : Presentation
Comment : Slides used to present this work at Cluster'19 conference (Albuquerque, New Mexico, 25/09/2019)
