When does OMP achieve exact recovery with continuous dictionaries? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
This paper presents new theoretical results on sparse recovery guarantees for a greedy algorithm, Orthogonal Matching Pursuit (OMP), in the context of continuous parametric dictionaries. Here, the continuous setting means that the dictionary is made up of an infinite (potentially uncountable) number of atoms. In this work, we rely on the Hilbert structure of the observation space to express our recovery results as a property of the kernel defined by the inner product between two atoms. Using a continuous extension of Tropp's Exact Recovery Condition, we identify two key notions of admissible kernel and admissible support that are sufficient to ensure exact recovery with OMP. We exhibit a family of admissible kernels relying on completely monotone functions for which admissibility holds for any support in the one-dimensional setting. For higher dimensional parameter spaces, an additional notion of axis admissibility is shown to be sufficient to ensure a form of "delayed" recovery. An additional algebraic condition involving a finite subset of (known) atoms further yields exact recovery guarantees. Finally, a coherence-based viewpoint on these results provides recovery guarantees in terms of a minimum separation assumption.
acha.pdf (556.99 Ko) Télécharger le fichier
hal-02099464 , version 1 (15-04-2019)
hal-02099464 , version 2 (15-04-2019)
hal-02099464 , version 3 (17-04-2019)
hal-02099464 , version 4 (21-06-2020)
  • HAL Id : hal-02099464 , version 3
Clément Elvira, Rémi Gribonval, Charles Soussen, Cédric Herzet. When does OMP achieve exact recovery with continuous dictionaries?. 2019. ⟨hal-02099464v3⟩
774 Consultations
676 Téléchargements
