, A Mathematical Introduction to Compressive Sensing, 2013.
Recovery of sparse translation-invariant signals with continuous basis pursuit, IEEE Transactions on Signal Processing, vol.59, issue.10, pp.4735-4744, 2011. ,
, Towards a Mathematical Theory of Super-resolution, vol.67, pp.906-956, 2014.
Exact support recovery for sparse spikes deconvolution, Foundations of Computational Mathematics, vol.15, issue.5, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00839635
Orthogonal matching pursuit: recursive function approximation with applications to wavelet decomposition, Proceedings of 27th Asilomar Conference on Signals, Systems and Computers, vol.1, pp.40-44, 1993. ,
Completely monotonic functions, Integral Transforms and Special Functions, vol.12, issue.4, pp.389-402, 2001. ,
Sparse approximate solutions to linear systems, SIAM Journal on Computing, vol.24, issue.2, pp.227-234, 1995. ,
Subset selection in regression, 2002. ,
Matching pursuits with time-frequency dictionaries, IEEE Transactions on Signal Processing, vol.41, issue.12, pp.3397-3415, 1993. ,
Some remarks on greedy algorithms, Advances in Computational Mathematics, vol.5, issue.1, pp.173-187, 1996. ,
The Orthogonal Super Greedy Algorithm and Applications in Compressed Sensing, IEEE Transactions on Information Theory, vol.58, issue.4, pp.2040-2047, 2012. ,
Orthogonal least squares methods and their application to non-linear system identification, International Journal of Control, vol.50, issue.5, pp.1873-1896, 1989. ,
Projection pursuit regression, Journal of the American Statistical Association, vol.76, issue.376, pp.817-823, 1981. ,
Projection pursuit, The Annals of Statistics, vol.13, issue.2, pp.435-475, 1985. ,
Optimized orthogonal matching pursuit approach, IEEE Signal Processing Letters, vol.9, issue.4, pp.137-140, 2002. ,
Greedy approximation, Acta Numerica, vol.17, pp.235-409, 2008. ,
Kernel Matching Pursuit, Machine Learning, vol.48, issue.3, pp.165-187, 2002. ,
Robust modeling with erratic data, Geophysics, vol.38, issue.5, pp.826-844, 1973. ,
Atomic decomposition by basis pursuit, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.33-61, 1998. ,
Regression shrinkage and selection via the lasso, Journal of the Royal Statistical Society. Series B (Methodological), vol.58, issue.1, pp.267-288, 1996. ,
Least angle regression, The Annals of Statistics, vol.32, issue.2, pp.407-499, 2004. ,
A fast iterative shrinkage-thresholding algorithm for linear inverse problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
Distributed optimization and statistical learning via the alternating direction method of multipliers, Foundations and Trends® in Machine Learning, vol.3, issue.1, pp.1-122, 2011. ,
Beyond sparsity: Recovering structured representations by ${\ell}?1$ minimization and greedy algorithms, Advances in Computational Mathematics, vol.28, issue.1, pp.23-41, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00544767
Beyond coherence: Recovering structured time-frequency representations, Applied and Computational Harmonic Analysis, vol.24, issue.1, pp.120-128, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00130123
Inferring sparse representations of continuous signals with continuous orthogonal matching pursuit, Advances in Neural Information Processing Systems, vol.27, pp.1215-1223, 2014. ,
Greed is super: A fast algorithm for superresolution, 2015. ,
Efficient atom selection strategy for iterative sparse approximations, iTWIST 2018 -International Traveling Workshop on Interactions between low-complexity data models and Sensing Techniques, pp.1-3, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01937501
Inverse problems in spaces of measures, ESAIM: Control, Optimisation and Calculus of Variations, vol.19, pp.190-218, 2012. ,
Exact reconstruction using Beurling minimal extrapolation, Journal of Mathematical Analysis and Applications, vol.395, issue.1, pp.336-354, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00678423
Compressed sensing off the grid, IEEE Transactions on Information Theory, vol.59, issue.11, pp.7465-7490, 2013. ,
Exact solutions to super resolution on semi-algebraic domains in higher dimensions, IEEE Transactions on Information Theory, vol.63, issue.1, pp.621-630, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01114328
The alternating descent conditional gradient method for sparse inverse problems, IEEE 6th International Workshop on Computational Advances in Multi-Sensor Adaptive Processing (CAMSAP), pp.57-60, 2015. ,
A low-rank approach to off-the-grid sparse deconvolution, SIAM Journal on Imaging Sciences, vol.12, issue.3, pp.1464-1500, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01672896
The sliding frank-wolfe algorithm and its application to super-resolution microscopy, Inverse Problems, vol.36, issue.1, p.14001, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01921604
Sparse inverse problems over measures: Equivalence of the conditional gradient and exchange methods, SIAM Journal on Optimization, vol.29, issue.2, pp.1329-1349, 2019. ,
On the linear convergence rates of exchange and continuous methods for total variation minimization, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02136598
On the global convergence of gradient descent for overparameterized models using optimal transport, Advances in Neural Information Processing Systems, vol.31, pp.3036-3046, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01798792
Sparse Optimization on Measures with Over-parameterized Gradient Descent, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02190822
Essai experimental et analytique : sur les lois de la dilatabilite des fluides elastique et sur celles de la force expansive de la vapeur de l'eau et de la vapeur de l'alkool, a differentes temperatures, vol.1795 ,
A multivariate generalization of Prony's method, Linear Algebra and its Applications, vol.490, pp.31-47, 2016. ,
MUSIC for single-snapshot spectral estimation: Stability and super-resolution, Applied and Computational Harmonic Analysis, vol.40, issue.1, pp.33-67, 2016. ,
ESPRIT-estimation of signal parameters via rotational invariance techniques, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.37, issue.7, pp.984-995, 1989. ,
FRESH-FRI-based single-image super-resolution algorithm, IEEE Transactions on Image Processing, vol.25, issue.8, pp.3723-3735, 2016. ,
Greed is good: Algorithmic results for sparse approximation, IEEE Transactions on Information Theory, vol.50, issue.10, pp.2231-2242, 2004. ,
Joint k-Step Analysis of Orthogonal Matching Pursuit and Orthogonal Least Squares, IEEE Transactions on Information Theory, vol.59, issue.5, pp.3158-3174, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00637003
On the exponential convergence of matching pursuits in quasi-incoherent dictionaries, IEEE Transactions on Information Theory, vol.52, issue.1, pp.255-261, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00544945
On sparse representations in arbitrary redundant bases, IEEE Transactions on Information Theory, vol.50, issue.6, pp.1341-1344, 2004. ,
Just relax: convex programming methods for identifying sparse signals in noise, IEEE Transactions on Information Theory, vol.52, issue.3, pp.1030-1051, 2006. ,
Relaxed Recovery Conditions for OMP/OLS by Exploiting Both Coherence and Decay, IEEE Transactions on Information Theory, vol.62, issue.1, pp.459-470, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01058077
Recovery of sparse signals using OMP and its variants: convergence analysis based on RIP, Inverse Problems, vol.27, issue.3, p.35003, 2011. ,
Improved RIP Analysis of Orthogonal Matching Pursuit, 2011. ,
A Remark on the Restricted Isometry Property in Orthogonal Matching Pursuit, IEEE Transactions on Information Theory, vol.58, issue.6, pp.3654-3656, 2012. ,
On the Recovery Limit of Sparse Signals Using Orthogonal Matching Pursuit, IEEE Transactions on Signal Processing, vol.60, issue.9, pp.4973-4976, 2012. ,
An Improved RIP-Based Performance Guarantee for Sparse Signal Recovery via Orthogonal Matching Pursuit, IEEE Transactions on Information Theory, vol.60, issue.9, pp.5702-5715, 2014. ,
Improved bounds on restricted isometry constant for orthogonal matching pursuit, Electronics Letters, vol.49, issue.23, pp.1487-1489, 2013. ,
A Sharp Restricted Isometry Constant Bound of Orthogonal Matching Pursuit, 2015. ,
, International Series in Pure and Applied Mathematics, 1976.
Blaster: An off-grid method for blind and regularized acoustic echoes retrieval, 2020 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.156-160, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02469901
Spike detection from inaccurate samplings, Applied and Computational Harmonic Analysis, vol.38, issue.2, pp.177-195, 2015. ,
Super-resolution of point sources via convex programming, Information and Inference: A, Journal of the IMA, vol.5, issue.3, pp.251-303, 2016. ,
Nudel man, The Markov Moment Problem and Extremal Problems, 1977. ,
Support Recovery for Sparse Super-Resolution of Positive Measures, Journal of Fourier Analysis and Applications, vol.23, issue.5, pp.1153-1194, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01270184
MultiDimensional sparse super-resolution, SIAM Journal on Mathematical Analysis, vol.51, issue.1, pp.1-44, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02411771
Most tensor problems are np-hard, J. ACM, vol.60, issue.6 ,
, Continuous dictionaries meet low-rank tensor approximations, in: iTwist 2020 -International Traveling Workshop on Interactions between low-complexity data models and Sensing Techniques, pp.1-3, 2020.
The convex geometry of linear inverse problems, Foundations of Computational Mathematics, vol.12, issue.6, pp.805-849, 2012. ,
Scattered data approximation, 2005. ,
, Kernel Methods for Pattern Analysis, 2004.
, Matrix Mathematics: Theory, Facts, and Formulas with Application to Linear Systems Theory, 2005.
, Proceedings of the [First] Berkeley Symposium on Mathematical Statistics and Probability, pp.115-123, 1949.
, , 1941.
, Nonlinear Programming, 1999.
Descartes' rule of signs, alternations of data sets, and balanced differences, The American Mathematical Monthly, vol.116, issue.4, pp.316-327, 2009. ,
