New interface
Journal articles
Multilinear Polynomial Systems: Root Isolation and Bit Complexity
Abstract : We exploit structure in polynomial system solving by considering polyno-mials that are linear in subsets of the variables. We focus on algorithms and their Boolean complexity for computing isolating hyperboxes for all the isolated complex roots of well-constrained, unmixed systems of multilinear polynomials based on resultant methods. We enumerate all expressions of the multihomogeneous (or multigraded) resultant of such systems as a determinant of Sylvester-like matrices, aka generalized Sylvester matrices. We construct these matrices by means of Weyman homological complexes, which generalize the Cayley-Koszul complex. The computation of the determinant of the resultant matrix is the bottleneck for the overall complexity. We exploit the quasi-Toeplitz structure to reduce the problem to efficient matrix-vector multiplication, which corresponds to multivariate polynomial multiplication, by extending the seminal work on Macaulay matrices of Canny, Kaltofen, and Yagati [9] to the multi-homogeneous case. We compute a rational univariate representation of the roots, based on the primitive element method. In the case of 0-dimensional systems we present a Monte Carlo algorithm with probability of success 1 − 1/2^r, for a given r ≥ 1, and bit complexity O_B (n^2 D^(4+e) (n^(N +1) + τ) + n D^(2+e) r (D +r)) for any e> 0, where n is the number of variables, D equals the multilinear Bézout bound, N is the number of variable subsets, and τ is the maximum coefficient bitsize. We present an algorithmic variant to compute the isolated roots of overdetermined and positive-dimensional systems. Thus our algorithms and complexity analysis apply in general with no assumptions on the input.
Complete list of metadata
Cited literature [55 references]  Display  Hide  Download
https://hal.inria.fr/hal-02099556
Contributor : Angelos Mantzaflaris Connect in order to contact the contributor
Submitted on : Monday, April 15, 2019 - 10:24:05 AM
Last modification on : Tuesday, October 25, 2022 - 4:25:04 PM
emt-bhomo-jsc.pdf
Identifiers
Citation
Ioannis Z. Emiris, Angelos Mantzaflaris, Elias Tsigaridas. Multilinear Polynomial Systems: Root Isolation and Bit Complexity. Journal of Symbolic Computation, 2021, Special Issue on Milestones in Computer Algebra (MICA 2016), 105, pp.145-164. ⟨10.1016/j.jsc.2020.06.005⟩. ⟨hal-02099556⟩
Share
Metrics
Record views
224
Files downloads
623
