A Mechanised Cryptographic Proof of the WireGuard Virtual Private Network Protocol - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2019
Une preuve cryptographique mécanisée du protocole de réseau privé virtuel WireGuard
Benjamin Lipp
Bruno Blanchet
Karthikeyan Bhargavan
WireGuard is a free and open source Virtual Private Network (VPN) that aims to replace IPsec and OpenVPN. It is based on a new cryptographic protocol derived from the Noise Protocol Framework. This paper presents the first mechanised cryptographic proof of the protocol underlying WireGuard, using the CryptoVerif proof assistant. We analyse the entire WireGuard protocol as it is, including transport data messages, in an ACCE-style model. We contribute proofs for correctness, message secrecy, forward secrecy, mutual authentication, session uniqueness, and resistance against key compromise impersonation, identity mis-binding, and replay attacks. We also discuss the strength of the identity hiding provided by WireGuard. Our work also provides novel theoretical contributions that are reusable beyond WireGuard. First, we extend CryptoVerif to account for the absence of public key validation in popular Diffie-Hellman groups like Curve25519, which is used in many modern protocols including WireGuard. To our knowledge, this is the first mechanised cryptographic proof for any protocol employing such a precise model. Second, we prove several indifferentiability lemmas that are useful to simplify the proofs for sequences of key derivations.
WireGuard est un logiciel de réseau privé virtuel (VPN) gratuit et open source qui cherche à remplacer IPsec et OpenVPN. Il est fondé sur un nouveau protocole cryptographique dérivé de la famille de protocoles Noise. Ce document présente la première preuve cryptographique mécanisée du protocole de WireGuard, obtenue avec l’assistant de preuve CryptoVerif. Nous analysons le protocole WireGuard en entier, tel qu’il est, y compris les messages de transport de données, dans un modèle du style ACCE. Nous obtenons des preuves de correction, secret des messages, forward secrecy, authentification mutuelle, unicité des sessions, et résistance contre des attaques d’imposture par compromis de clés, de mauvaise liaison d’identités, et de rejeu. Nous discutons également la robustesse de la protection des identités fournie par WireGuard. Notre travail fournit aussi de nouvelles contributions théoriques, réutilisables au-delà de WireGuard. Premièrement, nous étendons CryptoVerif pour tenir compte de l’absence de validation des clés publiques dans des groupes Diffie-Hellman populaires comme Curve25519, qui est utilisé dans beaucoup de protocoles modernes dont WireGuard. À notre connaissance, c’est la première preuve cryptographique mécanisée qui utilise un modèle aussi précis. Deuxièmement, nous prouvons plusieurs lemmes d’indifférentiabilité qui sont utiles pour simplifier les preuves de suites de dérivations de clés.
RR-9269v3.pdf (1.18 Mo) Télécharger le fichier
hal-02100345 , version 1 (15-04-2019)
hal-02100345 , version 2 (12-06-2019)
hal-02100345 , version 3 (29-06-2022)
  • HAL Id : hal-02100345 , version 3
Benjamin Lipp, Bruno Blanchet, Karthikeyan Bhargavan. A Mechanised Cryptographic Proof of the WireGuard Virtual Private Network Protocol. [Research Report] RR-9269, Inria Paris. 2019, pp.50. ⟨hal-02100345v3⟩
24479 Consultations
7722 Téléchargements
