The relative accuracy of $(x+y)*(x-y)$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational and Applied Mathematics Année : 2020
We consider the relative accuracy of evaluating $(x+y)(x-y)$ in IEEE floating-point arithmetic, when $x,y$ are two floating-point numbers and rounding is to nearest. This expression can be used, for example, as an efficient cancellation-free alternative to $x^2-y^2$ and (at least in the absence of underflow and overflow) is well known to have low relative error, namely, at most about $3u$ with $u$ denoting the unit roundoff. In this paper we propose to complement this traditional analysis with a finer-grained one, aimed at improving and assessing the quality of that bound. Specifically, we show that if the tie-breaking rule is to away then the bound $3u$ is asymptotically optimal (as the precision tends to $\infty$). In contrast, if the tie-breaking rule is to even, we show that asymptotically optimal bounds are now $2.25u$ for base two and $2u$ for larger bases, such as base ten. In each case, asymptotic optimality is obtained by the explicit construction of a certificate, that is, some floating-point input $(x,y)$ parametrized by $u$ and such that the error of the associated result is equivalent to the error bound as $u$ tends to zero. We conclude with comments on how $(x+y)(x-y)$ compares with $x^2$ in the presence of floating-point arithmetic, in particular showing cases where the computed value of $(x+y)(x-y)$ exceeds that of $x^2$.
relative_accuracy_xy_with_appendix (1).pdf (359.1 Ko) Télécharger le fichier
hal-02100500 , version 1 (16-04-2019)
hal-02100500 , version 2 (12-11-2019)
hal-02100500 , version 3 (17-05-2021)
Claude-Pierre Jeannerod. The relative accuracy of $(x+y)*(x-y)$. Journal of Computational and Applied Mathematics, 2020, pp.1-17. ⟨10.1016/j.cam.2019.112613⟩. ⟨hal-02100500v3⟩
860 Consultations
520 Téléchargements
