, xi) Assign := + and t := t +
, Diierential{Geometrical Methods in Statistics, vol.28, 1985.
On the nice behaviour of the Gaussian projection lter with small observation noise, Proceedings of the 3rd European Control Conference, 1995. ,
An introduction to nonlinear ltering, Stochastic Systems : the Mathematics of Filtering and Identiication and Applications, Les Arcs, 1980. ,
Time discretization of the Zakai equation for diiusion processes observed in correlated noise, Stochastics and Stochastics Reports, vol.35, issue.4, pp.233-256, 1991. ,
Stochastic diierential equations for the non{linear ltering problem, Osaka Journal of Mathematics, vol.9, issue.1, pp.19-40, 1972. ,
A diierential{geometric approach to approximate nonlinear ltering, Geometrization of Statistical Theory, pp.219-223, 1987. ,
Recursive Identiication, and Spaces of Linear Dynamical Systems. CWI Tracts 63{64, CWI, 1989. ,
New results on the projection lter, Proceedings of the 1st European Control Conference, pp.623-628, 1991. ,
Nonexistence of nite dimensional lters for conditional statistics of the cubic sensor problem, Systems & Control Letters, vol.3, issue.6, pp.331-340, 1983. ,
Stochastic Processes and Filtering Theory, of Mathematics in Science and Engineering, vol.64, 1970. ,
Stochastic Stability of Diierential Equations. Sijthoo and Noordhoo, 1980. ,
Numerical Solution of Stochastic Diierential Equations, Applications of Mathematics, vol.23, 1992. ,
Recursive nonlinear estimation : a geometric approach, Automatica, vol.26, issue.3, pp.545-555, 1990. ,
Recursive nonlinear estimation : geometry of a space of posterior densities, Automatica, vol.28, issue.2, pp.313-323, 1992. ,
Algebraic and geometric methods in nonlinear ltering, SIAM Journal on Control and Optimization, vol.22, issue.6, pp.817-844, 1984. ,
Stochastic Models, Estimation, and Control, 141{2 of Mathematics in Science and Engineering, vol.2, 1979. ,
EEciency of the extended Kalman lter for nonlinear systems with small noise, SIAM Journal on Applied Mathematics, vol.51, issue.3, pp.843-885, 1991. ,
Estimation of the quadratic variation of nearly observed semimartingales with application to ltering, SIAM Journal on Control and Optimization, vol.31, issue.2, pp.494-517, 1993. ,
Nonlinear ltering of one{dimensional diiusions in the case of a high signal{to{noise ratio, SIAM Journal on Applied Mathematics, vol.46, issue.6, pp.1098-1125 ,
, Campus scientifique, 615 rue du Jardin Botanique, vol.101
, BP 105, 78153 LE CHESNAY Cedex Unité de recherche INRIA Sophia-Antipolis, 2004 route des Lucioles
