, BGP Table Size Prediction and Potential Impact on Stability of Global Internet Infrastructure, 2017.
Reducing the size of routing tables for large-scale network simulation, Seventeenth Workshop on Parallel and Distributed Simulation, pp.115-122, 2003. ,
Wildcard compression of interdomain routing tables for openflow-based software-defined networking, 2014 Third European Workshop on Software Defined Networks, pp.25-30, 2014. ,
Bit weaving: A nonprefix approach to compressing packet classifiers in TCAMs, IEEE/ACM Transactions on Networking, vol.20, issue.2, pp.488-500, 2012. ,
, , 2017.
Firewall compressor: An algorithm for minimizing firewall policies, IEEE INFO-COM 2008 -The 27th Conference on Computer Communications, pp.176-180, 2008. ,
Classless inter-domain routing (CIDR): An address assignment and aggregation strategy, 1993. ,
Naf conversion: An efficient solution for the range matching problem in packet filters, 2011 IEEE 12th International Conference on High Performance Switching and Routing, pp.24-29, 2011. ,
Tree-based minimization of TCAM entries for packet classification, 2010 7th IEEE Consumer Communications and Networking Conference, pp.1-5, 2010. ,
Reducing the size of rule set in a firewall, 2007 IEEE International Conference on Communications, pp.1274-1279, 2007. ,
Optimising packet forwarding in multi-tenant networks using rule compilation, 2017 IEEE 16th International Symposium on Network Computing and Applications (NCA), pp.1-9, 2017. ,
Double-masked IP filter, 2015. ,
Survey and taxonomy of packet classification techniques, ACM Comput. Surv, vol.37, issue.3, pp.238-275, 2005. ,
Firewall filtering rules analysis for anomalies detection, IJSN, vol.3, pp.161-172, 2008. ,
Small forwarding tables for fast routing lookups, SIGCOMM Comput. Commun. Rev, vol.27, issue.4, pp.3-14, 1997. ,
Efficient mapping of range classifier into ternarycam, Proceedings 10th Symposium on High Performance Interconnects, pp.95-100, 2002. ,
Packet classifiers in ternary cams can be smaller, SIGMETRICS Perform. Eval. Rev, vol.34, issue.1, pp.311-322, 2006. ,
Packet classification using extended TCAMs, 11th IEEE International Conference on Network Protocols, 2003. Proceedings, pp.120-131, 2003. ,
On finding an optimal TCAM encoding scheme for packet classification, 2013 Proceedings IEEE INFOCOM, pp.2049-2057, 2013. ,
TCAM razor: A systematic approach towards minimizing packet classifiers in TCAMs, 2007 IEEE International Conference on Network Protocols, pp.266-275, 2007. ,
Ftrs: A mechanism for reducing flow table entries in software defined networks, Computer Networks, vol.122, pp.1-15, 2017. ,
Space-Efficient TCAMBased Classification Using Gray Coding, IEEE Transactions on Computers, vol.61, issue.1, pp.18-30, 2012. ,
DOI : 10.1109/tc.2010.267
Computing the minimum DNF representation of boolean functions defined by intervals, Discrete Applied Mathematics, vol.149, issue.1, pp.154-173, 2005. ,
Simple efficient TCAM based range classification, 2010 Proceedings IEEE INFOCOM, pp.1-5, 2010. ,
DOI : 10.1109/infcom.2010.5462192
Exact worst case TCAM rule expansion, IEEE Transactions on Computers, vol.62, issue.6, pp.1127-1140, 2013. ,
DOI : 10.1109/tc.2012.59
Fast and scalable layer four switching, SIGCOMM Comput ,
DOI : 10.1145/285237.285282
, Commun. Rev, vol.28, issue.4, pp.191-202, 1998.
On the complexity of classification functions, 38th International Symposium on Multiple Valued Logic, pp.57-63, 2008. ,
Zodiac Fx switch ,
