Journal articles
Consistent discretization of higher-order interface models for thin layers and elastic material surfaces, enabled by isogeometric cut-cell methods
Abstract : Many interface formulations, e.g. based on asymptotic thin interphase models or material surface theories, involve higher-order differential operators and discontinuous solution fields. In this article, we are taking first steps towards a variationally consistent discretization framework that naturally accommodates these two challenges by synergistically combining recent developments in isogeometric analysis and cut-cell finite element methods. Its basis is the mixed variational formulation of the elastic interface problem that provides access to jumps in displacements and stresses for incorporating general interface conditions. Upon discretization with smooth splines, derivatives of arbitrary order can be consistently evaluated, while cut-cell meshes enable discontinuous solutions at potentially complex interfaces. We demonstrate via numerical tests for three specific nontrivial interfaces (two regimes of the Benveniste–Miloh classification of thin layers and the Gurtin–Murdoch material surface model) that our framework is geometrically flexible and provides optimal higher-order accuracy in the bulk and at the interface.
Complete list of metadata
Cited literature [86 references]  Display  Hide  Download
https://hal.inria.fr/hal-02103057
Contributor : Angelos Mantzaflaris Connect in order to contact the contributor
Submitted on : Thursday, April 18, 2019 - 9:01:05 AM
Last modification on : Friday, July 8, 2022 - 10:04:45 AM
Manuscript.pdf
Identifiers
Collections
Citation
Zhilin Han, Stein K F Stoter, Chien-Ting Wu, Changzheng Cheng, Angelos Mantzaflaris, et al.. Consistent discretization of higher-order interface models for thin layers and elastic material surfaces, enabled by isogeometric cut-cell methods. Computer Methods in Applied Mechanics and Engineering, Elsevier, 2019, 350, pp.245-267. ⟨10.1016/j.cma.2019.03.010⟩. ⟨hal-02103057⟩
Share
Metrics
Record views
75
Files downloads
201
