Effect of interfacial zone on mechanical behavior and failure of fiber-reinforced composites, Journal of the Mechanics and Physics of Solids, vol.37, issue.1, pp.381-393, 1989. ,
Principles of composite material mechanics, 2011. ,
Curvature-dependent surface energy and implications for nanostructures, Journal of the Mechanics and Physics of Solids, vol.59, issue.1, pp.2103-2115, 2011. ,
Mussel-inspired surface chemistry for multifunctional coatings, Science, vol.318, issue.1, pp.426-430, 2007. ,
Recent advances in fiber/matrix interphase engineering for polymer composites, Progress in Materials Science, issue.1, pp.1-43, 2015. ,
Characterisation of interphase nanoscale property variations in glass fibre reinforced polypropylene and epoxy resin composites, Composites Part A: Applied Science and Manufacturing, vol.33, issue.1, pp.559-576, 2002. ,
Review of the role of the interphase in the control of composite performance on micro-and nano-length scales, Journal of Materials Science, vol.43, issue.1, pp.6747-6757, 2008. ,
Finite element modeling of thin layers, Computer Modeling in Engineering & Sciences, vol.5, issue.1, pp.497-514, 2004. ,
How thick is the interphase in an ultrathin polymer film? coarse-grained molecular dynamics simulations of polyamide-6,6 on graphene, The Journal of Physical Chemistry C, vol.117, issue.1, pp.5249-5257, 2013. ,
Effect of interfacial bonding on interphase properties in SiO2/epoxy nanocomposite: a molecular dynamics simulation study, ACS Applied Materials & Interfaces, vol.8, issue.1, pp.7499-7508, 2016. ,
On the modelling of thin interface layers in elastic and acoustic scattering problems, Quarterly Journal of Mechanics and Applied Mathematics, vol.47, issue.1, pp.17-42, 1994. ,
Asymptotic modelling of adhesive joints, Mechanics of Materials, vol.28, issue.1, pp.137-145, 1998. ,
Asymptotic models of dilute composites with imperfectly bonded inclusions, International Journal of Solids and Structures, vol.35, issue.1, pp.3239-3258, 1998. ,
Thin interphase/imperfect interface in elasticity with application to coated fiber composites, Journal of the Mechanics and Physics of Solids, vol.50, issue.1, pp.2509-2537, 2002. ,
Interfacial discontinuity relations for coupled multifield phenomena and their application to the modeling of thin interphases as imperfect interfaces, Journal of the Mechanics and Physics of Solids, vol.59, issue.1, pp.1413-1426, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00692839
The effective mechanical behaviour of composite materials with imperfect contact between the constituents, Mechanics of Materials, vol.4, issue.1, pp.197-208, 1985. ,
Thermoelastic properties of fiber composites with imperfect interface, Mechanics of Materials, vol.8, issue.1, pp.333-348, 1990. ,
The spherical inclusion with imperfect interface, Journal of Applied Mechanics, vol.58, issue.1, pp.444-449, 1991. ,
Statics and dynamics of structural interfaces in elasticity, International Journal of Solids and Structures, vol.39, issue.1, pp.4843-4865, 2002. ,
Stress concentration tensors of inhomogeneities with interface effects, Mechanics of Materials, vol.37, issue.1, pp.723-736, 2005. ,
An anti-interpenetration model and connections between interphase and interface models in particle-reinforced composites, International Journal of Mechanical Sciences, vol.47, issue.1, pp.701-708, 2005. ,
Imperfect soft and stiff interfaces in two-dimensional elasticity, Mechanics of Materials, vol.33, pp.309-323, 2001. ,
A continuum theory of elastic material surfaces, Archives for Rational Mechanics and Analysis, vol.57, pp.291-323, 1975. ,
Surface stress in solids, International Journal of Solids and Structures, vol.14, pp.431-440, 1978. ,
A general theory of curved deformable interfaces in solids at equilibrium, Philosophical Magazine A, vol.78, issue.1, pp.1093-1109, 1998. ,
Plain deformations of elastic solids with intrinsic boundary elasticity, Proceedings of the Royal Society of London A, vol.453, pp.853-877, 1997. ,
Elastic surface-substrate interactions, Proceedings of the Royal Society of London A, vol.455, pp.437-474, 1999. ,
Geometrically nonlinear higher-gradient elasticity with energetic boundaries, Journal of the Mechanics and Physics of Solids, vol.61, issue.1, pp.2381-2401, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00838679
A unified computational framework for bulk and surface elasticity theory: a curvilinear-coordinate-based finite element methodology, Computational Mechanics, vol.54, issue.1, pp.745-762, 2014. ,
Thermo-elastic properties of heterogeneous materials with imperfect interfaces: Generalized levin's formula and hill's connections, Journal of the Mechanics and Physics of Solids, vol.55, issue.1, pp.1036-1052, 2007. ,
Multiple interacting circular nano-inhomogeneities with surface/interface effects, Journal of the Mechanics and Physics of Solids, vol.56, pp.2298-2327, 2008. ,
Circular inhomogeneity with Steigmann-Ogden interface: Local fields, neutrality, and Maxwell's type approximation formula, International Journal of Solids and Structures, vol.135, pp.85-98, 2002. ,
Local fields and overall transverse properties of unidirectional composite materials with multiple nanofibers and Steigmann-Ogden interfaces, International Journal of Solids and Structures, vol.147, pp.166-182 ,
Shallow layer correction for spectral element like methods, Geophysical Journal International, vol.172, issue.1, pp.1135-1150, 2008. ,
URL : https://hal.archives-ouvertes.fr/insu-01399903
An Analysis of the Finite Element Method, 1973. ,
Combined asymptotic finite-element modeling of thin layers for scalar elliptic problems, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.1, pp.3265-3269, 2011. ,
An asymptotic approach to the adhesion of thin stiff films, Mechanics Research Communications, vol.58, issue.1, pp.24-35, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00825708
An XFEM/level set approach to modelling surface/interface effects and to computing the size-dependent effective properties of nanocomposites, Computational Mechanics, vol.42, issue.1, pp.119-131, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00692238
Three-dimensional numerical modelling by XFEM of spring-layer imperfect curved interfaces with applications to linearly elastic composite materials, International Journal for Numerical Methods in Engineering, vol.88, issue.4, pp.307-328, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00659383
Variationally consistent eXtended FE model for 3D planar and curved imperfect interfaces, Computer Methods in Applied Mechanics and Engineering, vol.267, issue.1, pp.434-457, 2013. ,
Isogeometric analysis: CAD, finite elements, NURBS, exact geometry and mesh refinement, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.1, pp.4135-4195, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01513346
Isogeometric analysis: Towards Integration of CAD and FEA, vol.1, 2009. ,
The Finite Cell Method: A review in the context of higher-order structural analysis of CAD and image-based geometric models, Archives of Computational Methods in Engineering, vol.22, issue.3, pp.391-455, 2015. ,
CutFEM: discretizing geometry and partial differential equations, International Journal for Numerical Methods in Engineering, vol.104, issue.7, pp.472-501, 2015. ,
An unfitted finite element method, based on Nitsche's method, for elliptic interface problems, Computer Methods in Applied Mechanics and Engineering, vol.191, pp.537-552, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-01352903
Unified analysis of discontinuous Galerkin methods for elliptic problems, SIAM Journal on Numerical Analysis, vol.39, issue.5, pp.1749-1779, 2002. ,
Exact results for the local fields and the effective moduli of fibrous composites with thickly coated fibers, Journal of the Mechanics and Physics of Solids, vol.71, issue.2, pp.219-238, 2014. ,
Small and large deformation analysis with the p-and B-spline versions of the Finite Cell Method, Computational Mechanics, vol.50, issue.4, pp.445-478, 2012. ,
An isogeometric design-through-analysis methodology based on adaptive hierarchical refinement of NURBS, immersed boundary methods, and T-spline CAD surfaces, Computer Methods in Applied Mechanics and Engineering, issue.3, pp.116-150, 2012. ,
Isogeometric analysis of the Cahn-Hilliard phase-field model, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.1, pp.4333-4352, 2008. ,
An isogeometric analysis approach to gradient damage models, International Journal for Numerical Methods in Engineering, vol.86, issue.1, pp.115-134, 2011. ,
Single-variable formulations and isogeometric discretizations for shear deformable beams, Computer Methods in Applied Mechanics and Engineering, vol.284, issue.1, pp.988-1004, 2015. ,
Variational boundary conditions based on the Nitsche method for fitted and unfitted isogeometric discretizations of the mechanically coupled Cahn-Hilliard equation, Journal of Computational Physics, vol.340, issue.1, pp.177-199, 2017. ,
The NURBS Book, vol.3, 1997. ,
Volumetric parameterization and trivariate b-spline fitting using harmonic functions, Computer Aided Geometric Design, vol.26, issue.6, pp.648-664, 2009. ,
Analysis-aware modeling: Understanding quality considerations in modeling for isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.2, pp.334-356, 2010. ,
Isogeometric Analysis: Representation of Geometry, vol.3, 2018. ,
Highly accurate surface and volume integration on implicit domains by means of moment-fitting, International Journal for Numerical Methods in Engineering, vol.96, issue.8, pp.512-528, 2013. ,
Higher-order accurate integration of implicit geometries, International Journal for Numerical Methods in Engineering, vol.106, issue.1, pp.323-371, 2016. ,
Efficient and accurate numerical quadrature for immersed boundary methods. Advanced Modeling and Simulation in Engineering Sciences, vol.2, pp.1-22, 2015. ,
Geometrically accurate, efficient, and flexible quadrature techniques for the tetrahedral finite cell method, Computer Methods in Applied Mechanics and Engineering, vol.310, pp.646-673, 2016. ,
High order unfitted finite element methods on level set domains using isoparametric mappings, Computer Methods in Applied Mechanics and Engineering, vol.300, pp.716-733, 2016. ,
Imposing Dirichlet boundary conditions with Nitsche's method and splinebased finite elements, International Journal for Numerical Methods in Engineering, vol.83, issue.2, pp.877-898, 2010. ,
Fictitious domain finite element methods using cut elements: Ii. a stabilized Nitsche method, Applied Numerical Mathematics, vol.62, issue.4, pp.328-341, 2012. ,
A robust Nitsche's formulation for interface problems with spline-based finite elements, International Journal for Numerical Methods in Engineering, vol.104, issue.7, pp.676-696, 2015. ,
The non-symmetric Nitsche method for the parameter-free imposition of weak boundary and coupling conditions in immersed finite elements, Computer Methods in Applied Mechanics and Engineering, vol.309, pp.625-652, 2016. ,
Preconditioning immersed isogeometric finite element methods with application to flow problems, vol.3, 2017. ,
A stabilized Nitsche cut finite element method for the Oseen problem, Computer Methods in Applied Mechanics and Engineering, vol.3, issue.2, 2017. ,
The finite cell method for three-dimensional problems of solid mechanics, Computer Methods in Applied Mechanics and Engineering, vol.197, pp.3768-3782, 2001. ,
Numerical integration of discontinuities on arbitrary domains based on moment fitting, Computational Mechanics, vol.57, issue.6, pp.979-999, 2001. ,
A Nitsche-based non-intrusive coupling strategy for global/local isogeometric structural analysis, Computer Methods in Applied Mechanics and Engineering, vol.340, issue.4, pp.253-277, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01816443
Linear elasticity, Discontinuous Galerkin Methods for Solving Elliptic and Parabolic Equations, chapter 5, pp.109-115, 2008. ,
A hybridizable discontinuous Galerkin method for linear elasticity, International Journal for Numerical Methods in Engineering, vol.80, issue.8, pp.1058-1092, 2009. ,
Mixed and hybrid finite element methods, vol.4, 1991. ,
Discontinuous galerkin methods for incompressible and nearly incompressible elasticity by Nitsche's method, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.17, pp.1895-1908, 2002. ,
A robust Nitsche's formulation for interface problems, Computer Methods in Applied Mechanics and Engineering, vol.225, issue.3, pp.44-54, 2012. ,
A unified approach for embedded boundary conditions for fourth-order elliptic problems, International Journal for Numerical Methods in Engineering, vol.104, issue.7, pp.655-675, 2015. ,
Multipatch discontinuous Galerkin isogeometric analysis, Isogeometric Analysis and Applications, pp.1-32, 2015. ,
Size-dependent elastic properties of nanosized structural elements, Nanotechnology, vol.11, issue.3, p.139, 2000. ,
Size-dependent Eshelby's tensor for embedded nano-inclusions incorporating surface/interface energies, Journal of Applied Mechanics, vol.71, issue.5, pp.663-671, 2004. ,
Micro-to-macro transition accounting for general imperfect interfaces, Computer Methods in Applied Mechanics and Engineering, vol.317, issue.6, pp.274-317, 2017. ,
Cut finite element modeling of linear membranes, Computer Methods in Applied Mechanics and Engineering, vol.310, issue.6, pp.98-111, 2016. ,
Embedded shell finite elements: Solid-shell interaction, surface locking, and application to image-based bio-structures, Computer Methods in Applied Mechanics and Engineering, vol.335, issue.6, pp.298-326, 2018. ,
Variationally consistent isogeometric analysis of trimmed thin shells at finite deformations, based on the step exchange format, Computer Methods in Applied Mechanics and Engineering, vol.336, issue.6, pp.39-79, 2018. ,
