Convergence of metadynamics: discussion of the adiabatic hypothesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Annals of Applied Probability Année : 2021
By drawing a parallel between metadynamics and self interacting models for polymers, we study the longtime convergence of the original metadynamics algorithm in the adiabatic setting, namely when the dynamics along the collective variables decouples from the dynamics along the other degrees of freedom. We also discuss the bias which is introduced when the adiabatic assumption does not holds.
hal-02104961 , version 1 (19-04-2019)
Benjamin Jourdain, Tony Lelièvre, Pierre-André Zitt. Convergence of metadynamics: discussion of the adiabatic hypothesis. The Annals of Applied Probability, 2021, 31 (5), pp.2441-2477. ⟨10.1214/20-AAP1652⟩. ⟨hal-02104961⟩
226 Consultations
0 Téléchargements
