Video Motion Stylization by 2D Rigidification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces a video stylization method that increases the apparent rigidity of motion. Existing stylization methods often retain the 3D motion of the original video, making the result look like a 3D scene covered in paint rather than a 2D painting of a scene. In contrast, traditional hand-drawn animations often exhibit simplified in-plane motion, such as in the case of cutout animations where the animator moves pieces of paper from frame to frame. Inspired by this technique, we propose to modify a video such that its content undergoes 2D rigid transforms. To achieve this goal, our approach applies motion segmentation and optimization to best approximate the input optical flow with piecewise-rigid transforms, and re-renders the video such that its content follows the simplified motion. The output of our method is a new video and its optical flow, which can be fed to any existing video stylization algorithm.
paper_comp.pdf (17.67 Mo) Télécharger le fichier
hal-02106047 , version 1 (22-04-2019)
  • HAL Id : hal-02106047 , version 1
Johanna Delanoy, Adrien Bousseau, Aaron Hertzmann. Video Motion Stylization by 2D Rigidification. Expressive 2019 - 8th ACM/ Eurographics Proceedings of the Symposium, May 2019, Genoa, Italy. ⟨hal-02106047⟩
212 Consultations
240 Téléchargements
