DeCP-Live: A Web-Interface for DeCP, a Distributed High-Throughput CBIR System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
A vast number of algorithms and methods are proposed and developed every year in the domain of indexing and searching multimedia documents. Much of this work results in published papers and some sources are made openly available, but rarely will you find a fully working end-to-end system that has been pre-installed, configured, and is ready-to-go on a virtual machine available for download. In this paper we present such a system, the DeCPLive web interface, that is built on top of the distributed, high-throughput, content-based image retrieval algorithm DeCP The virtual machine is ready-to-go as on it we have pre-installed services, indexed openly available datasets, binaries for DeCP and DeCPLive as well as the source code.
Fichier non déposé
hal-02106908 , version 1 (23-04-2019)
Laurent Amsaleg, Gylfi Thor Gudmundsson, Christian Andreas Jacobsen, Hilmar Tryggvason, Bjorn Thor Jonsson. DeCP-Live: A Web-Interface for DeCP, a Distributed High-Throughput CBIR System. CBMI 2018 - International Conference on Content-Based Multimedia Indexing, Sep 2018, La Rochelle, France. pp.1-4, ⟨10.1109/CBMI.2018.8516275⟩. ⟨hal-02106908⟩
66 Consultations
0 Téléchargements
