Study on Vegetation Classification Based on Spectral Knowledge Base
A framework about spectral based vegetation classification was proposed, which serves as a core methodology of the vegetation spectral knowledge base. The hyperspectral reflectances of 13 types of plants were measured by an ASD FieldSpec 4 spectroradiometer. Two forms of spectral features were used for representing the key spectral characteristics of plants, including Vegetation index (VI) and spectral shape features. Based on these spectral features, a sensitivity analysis was performed to identify the most important features for establishing the classifier. The analysis of variance (ANOVA) and the cross-correlation analysis were applied to derive the sensitivity of features and remove features that have high correlations. Then, a classification method for differentiating plants was established by coupling some spectral similarity measures (e.g., ED) with some classification methods (e.g., BPANN and SVM). The results of discrimination analysis showed that a highest accuracy was produced by SVM with the OAA over 99% when using 7 sensitive VIs. The results suggested the framework about spectral based vegetation classification can form a basis for spectral knowledge base and application technology and further achieve a wide range of plant classification based on remote sensing.
