China's Climate Resources, Science and Technology Press, 1993. ,
Analysis of Drought Disaster in China in nearly 50 years, China Agricultural Meteorology, vol.24, issue.1, pp.8-11, 2003. ,
Research on Drought Monitoring in China Using Remote Sensing Methods. Remote Sensing Information, vol.24, pp.55-58, 2005. ,
Method and Application of Crop Remote Sensing Monitoring and Application, 2013. ,
Introduction to Remote Sensing, 2001. ,
, Meteorological drought:policy statement, 1997.
Research on Drought Disaster in China and Countermeasures, 1999. ,
Preparing for drouhgt:a methodology, Hazardsand Disaster Series, vol.II. Routledge, pp.89-104, 2002. ,
, Hunks R J. Reflection of Radiant Energy from Soils, vol.100, issue.2, pp.135-138, 1965.
Application of Thermal Modeling in the Geologic Interpretation of IR images, vol.24, pp.2017-2041, 1971. ,
Thermal Inertia Mapping: A new view of the earth, Journal of Geophysical Research, vol.82, issue.18, pp.25-31, 1977. ,
A Simple Thermal Model of the Earth's Surface for Geologic Mapping by Temote Sensing, Journal of Geophysical Research, vol.82, issue.11, p.1673, 1977. ,
The Application of Meteorological Satellite Remote Sensing in DroughtMonitoring, Disaster science, vol.12, pp.25-29, 1996. ,
Research on the Operational Methods of Remote Sensing Drought Monitoring based on MODIS Data, vol.24, pp.1-6, 2006. ,
Application of NOAA/HAVRR Data to Monitor Soil Moisture and Drought Area, Journal of Disaster Prevention and Mitigation Engineering, vol.25, issue.2, pp.157-161, 2005. ,
Discussion on Soil Moisture Content using Thermal Inertia Method, China Agricultural Meteorology, vol.26, issue.4, pp.215-219, 2005. ,
Application of Vegetation Water Supply Index method in Drought Monitoring in Inner Mongolia. Inner Mongolia agricultural science and technology, vol.20, pp.58-62, 2008. ,
Research on Rmote Snsing Mnitoring of Dought Dsasters in Fjian Povince, Meteorology, vol.30, issue.3, pp.22-25, 2004. ,
Application of Rmote Snsing Mnitoring of Dought in Gangdong Povince in 2004, Journal of Topical Mteorology, vol.22, issue.3, pp.237-240, 2006. ,
The Aplication of the Remote Vegetation Index in the Severe Drought Monitoring in 1992, Journal of Remote Sensing, vol.24, issue.2, pp.106-112, 1994. ,
NOAA/AVHRR data in Drought Monitoring in Heilongjiang, Journal of Harbin Institute of Technology, vol.10, issue.2, pp.51-53, 2005. ,
Application of NOAA/AVHRR data in Grassland Drought Monitoring in Pastoral areas of Qinghai Province, Journal of Applied Meteorology, vol.9, issue.4, pp.496-500, 1998. ,
Analysis of Climate and Vegetation 8 Characteristics of Drought Conditions in the Yellow River Basin, Journal of natural resources, vol.18, issue.2, pp.136-141, 2003. ,
Monitoring Soil Moisture Dynamics using Satellite Umaging radar in Northeastern Jordan, Applied Geography, vol.19, issue.4, pp.325-344, 1999. ,
Soil Moisture Evaluation by means of Mult-itemporal ERS SAR PRI Images and Interferometric Coherence, Journal of Hydrology, vol.234, issue.3-4, pp.162-169, 2000. ,
Comprehensive active and passive microwave data monitoring soil moisture change, Journal of remote sensing, vol.6, issue.6, pp.481-485, 2002. ,
Application of Polarization Decomposition Technology in Estimating Soil Moisture Change in Vegetation Cover Area. Remote sensing information, vol.5, pp.3-6, 2005. ,
Soil Moisture Mapping and AMSR-E Validation using the PSR in SM EX02, Remote Sensing of Environment, vol.103, issue.2, pp.127-139, 2006. ,
