Economic impact of water-limited conditions on cereal grain production, Ribaut JM (ed) Drought Adaptation in Cereals, p.7, 2006. ,
Enhancing drought tolerance in C4 crops, J. Exp. Bot, vol.62, pp.3135-3153, 2011. ,
Drought and ecosystem carbon cycling, Agric. Forest. Meteorol, vol.151, pp.765-773, 2011. ,
Intrinsic and environmental response pathways that regulate root system architecture, Plant Cell Environ, vol.28, issue.1, pp.67-77, 2005. ,
RootScan: software for highthroughput analysis of root anatomical traits, Plant Soil, vol.357, pp.189-203, 2012. ,
Root anatomical phenes associated with water acquisition from drying soil: targets for crop improvement, J. Exp. Bot, vol.65, pp.6155-6166, 2014. ,
Relationships between xylem vessel characteristics, calculated axial hydraulic conductance and size-controlling capacity of peach rootstocks, Ann. of bot, vol.105, pp.327-331, 2010. ,
Seminal root morphology and water use of wheat I. Environmental effects, Crop Sci, vol.21, pp.249-252, 1981. ,
Roots and drought resistance, Agric. Water Manag, vol.7, pp.265-280, 1983. ,
Three-dimensional reconstruction of maize roots and quantitative analysis of metaxylem vessels based on Xray micro-computed tomography, Can. J. Plant Sci, vol.98, pp.457-466, 2018. ,
Dynamic root responses to drought and rewatering in two wheat (Triticum aestivum) genotypes, Plant Soil, vol.391, issue.1, pp.139-152, 2015. ,
X-ray micro-computed CT tomography (?CT) for non-destructive characterisation of food microstructure, Trends Food Sci. Technol, vol.47, pp.10-24, 2016. ,
Increased leaf mesophyll porosity following transient retinoblastoma-related protein silencing is revealed by microcomputed tomography imaging and leads to a system-level physiological response to the altered cell division pattern, Plant J, vol.76, pp.914-929, 2013. ,
Non-destructive estimation of maize (Zea mays L.) kernel hardness by means of an X-ray micro-computed tomography (?CT) density calibration, Food Bioproc. Tech, vol.8, pp.1419-1429, 2015. ,
