Using hyperspectral remote sensing to estimate canopy chlorophyll density of wheat under yellow rust stress ,
, Spectroscopy and Spectral Analysis, vol.30, pp.2243-2247, 2010.
Study on relationship between new characteristic parameters of spectral curve and chlorophyll content for rice ,
, Spectroscopy and Spectral Analysis, vol.31, issue.1, pp.188-191, 2011.
Nondestructive Estimation of Leaf Chlorophyll Content in Grapes ,
, American Journal of Enology & Viticulture, vol.59, issue.3, pp.299-305, 2008.
Construction of apple tree leaves nutrients prediction model based on spectral analysis, Transactions of the Chinese Society of Agricultural Engineering, vol.29, issue.8, pp.171-178, 2013. ,
Correlation between apple leaf spectral reflectance and chlorophyll content and leaf total nitrogen, 2009. ,
Study on modeling total and phosphorus content of Korla Fragrant Pear leaves based on Hyperspectrum by analysis ,
Hyperspectral Estimation on Chlorophyll and Water Contents in Young Apple Leaves ,
Inverting wheat leaf area index based on HJ-CCD remote sensing data and random forest algorithm, Transactions of the Chinese Society of Agricultural Engineering, vol.2016, issue.3, pp.149-154 ,
Remote sensing estimation of SPAD value for wheat leaf based on GF-1 data, Transactions of the Chinese Society of Agricultural Machinery, vol.46, pp.273-281, 2015. ,
Estimation of wheat leaf SPAD value using RF algorithmic model and remote sensing data, Transactions of the Chinese Society of Agricultural Machinery, vol.46, pp.259-265, 2015. ,
, Hyperspectral Estimation of Apple Tree Canopy LAI Based on SVM and RF Regression
, Spectroscopy and Spectral Analysis, vol.36, pp.800-805, 2016.
Comparative of remote sensing estimation models of winter wheat biomass based on random forest algorithm, Transactions of the Chinese Society of Agricultural Engineering, issue.18, pp.175-182, 2016. ,
Chlorophylls and carotenoids: pigments of photosynthetic biomembranes, Methods in Enzymology, vol.148, issue.34, pp.350-382, 1987. ,
Reflectance indices associated with physiological changes in nitrogen-and water-limited sunflower leaves ,
, Remote Sensing of Environment, vol.48, issue.2, pp.135-146, 1994.
Reflectance assessment of mite effects on apple trees, International Journal of Remote Sensing, vol.16, issue.14, pp.2727-2733, 2010. ,
Estimating Corn Leaf Chlorophyll Concentration from Leaf and Canopy Reflectance ,
, Remote Sensing of Environment, vol.74, issue.2, pp.229-239, 2000.
Hyperspectral vegetation indices and novel algorithms for predicting green LAI of crop canopies: Modeling and validation in the context of precision agriculture ,
, Remote Sensing of Environment, vol.90, issue.3, pp.337-352, 2004.
Integrated narrow-band vegetation indices for prediction of crop chlorophyll content for application to precision agriculture ,
, Remote Sensing of Environment, vol.81, issue.2, pp.416-426, 2002.
The MERIS terrestrial chlorophyll index, International Journal of Remote Sensing, vol.25, issue.23, pp.5403-5413, 2004. ,
Relationships between leaf pigment content and spectral reflectance across a wide range of species, leaf structures and developmental stages ,
, Remote Sensing of Environment, vol.81, issue.2-3, pp.337-354, 2002.
Red and photographic infrared linear combinations for monitoring vegetation ,
, Remote Sensing of Environment, vol.8, issue.2, pp.127-150, 1979.
Optical Properties and Nondestructive Estimation of Anthocyanin Content in Plant Leaves ,
, , vol.74, pp.38-45, 2001.
Estimating PAR absorbed by vegetation from bidirectional reflectance measurements ,
, Remote Sensing of Environment, vol.51, issue.3, pp.375-384, 1995.
A modified soil adjusted vegetation index ,
, Remote Sensing of Environment, vol.48, issue.2, pp.119-126, 1994.
High spectral resolution: Determination of spectral shifts between the red and near infrared, XXVII Part B7, pp.750-760, 1988. ,
Angular dependence of maize and sugar beet VIs from directional CHRIS/Proba data, 2006. ,
Remote estimation of chlorophyll content in higher plant leaves, International Journal of Remote Sensing, vol.18, issue.12, pp.2691-2697, 1997. ,
Red edge spectral measurements from sugar maple leaves, International Journal of Remote Sensing, vol.14, issue.8, pp.1563-1575, 1993. ,
Scaling-up and model inversion methods with narrowband optical indices for chlorophyll content estimation in closed forest canopies with hyperspectral data, IEEE Transactions on Geoscience & Remote Sensing, vol.39, issue.7, pp.1491-1507, 2001. ,
The chlorophyll content of maize (zea mays) derived with the Airborne Imaging Spectrometer AVIS, 2001. ,
Steady-state chlorophyll a, fluorescence detection from canopy derivative reflectance and double-peak, red-edge effects ,
, Remote Sensing of Environment, vol.84, issue.2, pp.283-294, 2003.
The use of high spectral resolution bands for estimating absorbed photosynthetically active radiation (Apar.), Proceedings of the Sixth Symposium on Physical Measurements and Signatures in Remote Sensing, p.299, 1994. ,
New spectral indicator assessing the efficiency of crop nitrogen treatment in corn and wheat ,
, Remote Sensing of Environment, vol.114, issue.9, pp.1987-1997, 2010.
Newly Combined Spectral Indices to Improve Estimation of Total Leaf Chlorophyll Content in Cotton ,
, IEEE Journal of Selected Topics in Applied Earth Observations & Remote Sensing, vol.1, issue.1, pp.4589-4600, 2014.
Random Forests ,
, Machine Learning, vol.45, pp.5-32, 2001.
Bagging Predictors ,
, Machine Learning, vol.24, pp.123-140, 1996.
An Efficient Method To Estimate Bagging's Generalization Error, pp.41-55, 1999. ,
Predictive modeling on multivariate liner regression, Journal of Beijing University of Aeronautics and Astronautics, vol.33, issue.4, pp.500-504, 2007. ,
Random forest algorithm and regional application of spectral inversion model for estimating canopy nitrogen concentration in rice, J]. Journal of Remote Sensing, vol.18, issue.4, pp.934-945, 2014. ,
Mining data with random forests: A survey and results of new tests, Pattern Recognition, vol.44, pp.330-349, 2011. ,
