Transgenic approaches for abiotic stress tolerance in plants:retrospect and prospects, Plant Cell Rep, vol.27, pp.411-424, 2008. ,
Mechanisms of salinity tolerance, Annu. Rev. Plant Biol, vol.59, pp.651-681, 2008. ,
Development and prospect of the research on salt-affected soils in China, Pedol. Sin, vol.45, pp.837-845, 2008. ,
Dentification of saline soils with multiyear remote sensing of crop yields, In Soil Sci Soc Am, vol.71, pp.777-783, 2007. ,
Improving crop salt tolerance, Journal of Experimental Botany, vol.55, pp.307-319, 2004. ,
Accumulation of low molecular weight solutes in water-stressed tropical legumes, Phytochem, vol.23, pp.1007-1015, 1984. ,
Temporal progression of gene expression responses to salt shock in maize roots, Plant Mol Biol, vol.52, pp.873-891, 2003. ,
Metabolism and functions of gamma-aminobutyric acid, Trend in Plant Sci, vol.4, issue.11, pp.446-452, 1999. ,
Metabolism, enzymology and possible roles of 4-aminobutyrate in higher plants, In: Phytochem, vol.29, pp.367-375, 1990. ,
Accumulation of ?-amniobutyric acid in nodulated soybean in response to drought stress, Physiol. Plant, vol.102, pp.79-86, 1998. ,
Gamma aminobutyrate: from intellectual curiosity to practical pest control, Can. J. Bot, vol.81, pp.1045-1048, 2003. ,
Amino acid as indicators of physiological stress in common reed Phragmites australis affected by an extra flood, Aquatic Bot, vol.79, pp.277-294, 2004. ,
Mechanical stimulation 4-aminobutyric acid (GABA) synthesis and growth inhibition in soybean hypocotyls tissue, Can. J. Bot, vol.78, pp.119-123, 2000. ,
Gama-aminobutyric stimulates ethylene biosynthesis in sunflower, Plant Physiol, vol.115, issue.1, pp.129-135, 1997. ,
?-aminobutyric acid promoted stem elongation in Stellaria longipes: the role of ethylene, Plant Growth Regul, vol.26, pp.131-137, 1998. ,
Effects of whole plant and local heating on the ABA content in cucumber seedling leaves and roots and on their heat tolerance, Plant Physiol, vol.50, pp.90-94, 2003. ,
GABA signaling: a conserved and ubiquitous mechanism, Trends in Cell Biol, vol.13, issue.12, pp.607-610, 2003. ,
Putative role of ?-aminobutyric acid (GABA) as a long-distance signal in up-regulation of nitrate uptake in Brassica napus L, Plant Cell Environ, vol.27, pp.1035-1046, 2004. ,
Pollen tube growth and guidance is regulated by POP2, an Arabidopsis gene that control GABA levels, Cell, vol.114, pp.47-59, 2003. ,
Response of reactive oxygen metabolism in melon chloroplasts to short-term salinity-alkalinity stress regulated by exogenous ?-aminobutyric acid, Chinese Journal of Applied Ecology, vol.26, issue.12, pp.3746-3752, 2015. ,
Exogenous GABA application transiently improves the tolerance to root hypoxia on a sensitive genotype of Prunus rootstock, Environmental and Experimental Botany, vol.125, pp.52-66, 2016. ,
Exogenously supplied compatible solutes rapidly ameliorate NaCl-induced potassium eZux from barley roots, Plant Cell Physiol, vol.46, pp.1924-1933, 2005. ,
Amino acids regulate salinity-induced potassium efflux in barley root epidermis, Planta, vol.225, pp.753-761, 2007. ,
Comparison of extractive methods of Na + and K + in wheat leave, Plant Physiology Communications, vol.31, issue.1, pp.50-52, 1995. ,
Ion response of sunflower at sprouting stage to mixed salt stress ,
, Chinese), vol.25, pp.720-729, 2017.
Impact of exogenous GABA treatments on endogenous GABA metabolism in anthurium cut flowers in response to postharvest chilling temperature, Plant Physiology and Biochemistry, vol.106, pp.11-15, 2016. ,
Salt and drought stress signal transduction in plants, Annual Rev Plant Biol, vol.53, pp.247-273, 2002. ,
NaCl-induced alternations of cellular and tissue ion fluxes in roots of salt-resistant and salt-sensitive poplar species, Plant Physiol, vol.149, pp.1141-1153, 2009. ,
Role of tonoplast proton pumps and Na + /H + antiport system in salt tolerance of Populus euphratica oliv, Plant Growth Regul, vol.29, pp.23-34, 2010. ,
K + efflux and retention in response to NaCl stress do not predict salt tolerance in contrasting genotypes of rice, Oryza sativa L.). In: PLOS ONE, vol.8, pp.1-16, 2013. ,
Ion transport in broad bean leaf mesophyll under saline conditions, Planta, vol.240, pp.729-743, 2014. ,
H2O2 and cytosolic Ca 2+ signals triggered by the PM H + -coupled transport system mediate K + /Na + homeostasis in NaCl-stressed Populus euphratica cells, Plant Cell Environ, vol.33, pp.943-958, 2010. ,
Assessing the role of root plasma membrane and tonoplast Na + /H + exchangers in salinity tolerance in wheat: in planta quantification methods, Plant Cell Environ, vol.34, pp.947-961, 2011. ,
Dose-Dependent Effects of Coronatine on Cotton Seedling Growth Under Salt Stress, Journal of Plant Growth Regulation, vol.34, pp.651-664, 2015. ,
Salt tolerance of cotton: some new advances, Crit Rev Plant Sci, vol.21, pp.1-30, 2002. ,
