Characterization of failures in an ip backbone, Proceedings of IEEE INFOCOM, 2004. ,
Shrink: A tool for failure diagnosis in ip networks, Proceedings of the 2005 ACM SIGCOMM workshop on Mining network data, pp.173-178, 2005. ,
Internet-draft: draft-manyinference-srlg-02. txt, 2001. ,
Routing, flow, and capacity design in communication and computer networks, 2004. ,
Openflow: enabling innovation in campus networks, ACM SIGCOMM Computer Communication Review, vol.38, issue.2, pp.69-74, 2008. ,
Ip restoration vs. wdm protection: Is there an optimal choice?, IEEE network, vol.14, issue.6, 2000. ,
A survey on fault management in software-defined networks, IEEE Communications Surveys & Tutorials, 2017. ,
Congestion-aware single link failure recovery in hybrid sdn networks, Proceedings of IEEE INFOCOM, 2015. ,
Network architecture for joint failure recovery and traffic engineering, Proceedings of the ACM SIGMETRICS joint international conference on Measurement and modeling of computer systems, pp.97-108, 2011. ,
Openflow-based segment protection in ethernet networks, Journal of Optical Communications and Networking, vol.5, issue.9, 2013. ,
Poster: Design of Survivable SDN/NFV-enabled Networks with Bandwidth-optimal Failure Recovery, Proc. of IFIP Networking, 2019. ,
Fast ip network recovery using multiple routing configurations, Proceedings of IEEE INFOCOM, 2006. ,
Post-failure routing performance with multiple routing configurations, Proceedings of IEEE INFOCOM, 2007. ,
Structure preserving reductions among convex optimization problems, Journal of Computer and System Sciences, vol.21, issue.1, pp.136-153, 1980. ,
Analytical approach to parallel repetition, Proceedings ACM STOC, 2014. ,
Optimal network service chain provisioning, IEEE/ACM Transactions on Networking, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01920951
Column generation, vol.5, 2006. ,
Automation and combination of linear-programming based stabilization techniques in column generation, INFORMS Journal on Computing, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01077984
Partitioning procedures for solving mixed-variables programming problems, Numerische mathematik, vol.4, issue.1, 1962. ,
Some optimal inapproximability results, Journal of the ACM (JACM), vol.48, issue.4, pp.798-859, 2001. ,
Sndlib 1.0âsurvivable network design library, Networks, vol.55, issue.3, 2010. ,
Routing of multipoint connections, IEEE journal on selected areas in communications, vol.6, issue.9, pp.1617-1622, 1988. ,
Optimizing ospf/is-is weights in a changing world, IEEE journal on selected areas in communications, vol.20, issue.4, pp.756-767, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-01255600
A survey on software defined networking with multiple controllers, J. Netw. Comput. Appl, vol.103, issue.C, pp.101-118, 2018. ,
