Effective neighborhood search with optimal splitting and adaptive memory for the team orienteering problem with time windows, Computers & Operations Research, vol.123, issue.15, p.105039, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02890475
A unified exact method for solving different classes of vehicle routing problems, Mathematical Programming, vol.120, issue.2, pp.347-380, 2008. ,
An exact algorithm for the vehicle routing problem based on the set partitioning formulation with additional cuts, Mathematical Programming, vol.115, issue.2, pp.351-385, 2007. ,
New Route Relaxation and Pricing Strategies for the Vehicle Routing Problem, Operations Research, vol.59, issue.5, pp.1269-1283, 2011. ,
An Exact Algorithm for the Two-Echelon Capacitated Vehicle Routing Problem, Operations Research, vol.61, issue.2, pp.298-314, 2013. ,
A Lower Bound for the Split Delivery Vehicle Routing Problem, Operations Research, vol.48, issue.5, pp.801-810, 2000. ,
A Branch-and-Cut method for the Capacitated Location-Routing Problem, Computers & Operations Research, vol.38, issue.6, pp.931-941, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-02474696
A large neighbourhood based heuristic for two-echelon routing problems, Computers & Operations Research, vol.76, pp.208-225, 2016. ,
A new exact algorithm for the multi-depot vehicle routing problem under capacity and route length constraints, Discrete Optimization, vol.12, pp.129-146, 2014. ,
Lower and upper bounds for the two-echelon capacitated location-routing problem, Computers & Operations Research, vol.39, issue.12, pp.3185-3199, 2012. ,
A computational comparison of flow formulations for the capacitated location-routing problem, Discrete Optimization, vol.10, issue.4, pp.263-295, 2013. ,
Models for evaluating and planning city logistics systems, Transportation science, vol.43, issue.4, pp.432-454, 2009. ,
Two-echelon vehicle routing problem: A satellite location analysis, Procedia -Social and Behavioral Sciences, vol.2, issue.3, pp.5944-5955, 2010. ,
Location-routing models for twoechelon freight distribution system design, 2011. ,
A survey on two-echelon routing problems, Computers & Operations Research, vol.55, pp.185-199, 2015. ,
Branch-and-Price?Based Algorithms for the Two-Echelon Vehicle Routing Problem with Time Windows, Transportation Science, vol.53, issue.2, pp.463-479, 2019. ,
JuMP: A Modeling Language for Mathematical Optimization, SIAM Review, vol.59, issue.2, pp.295-320, 2017. ,
The two-echelon capacitated vehicle routing problem, 2007. ,
URL : https://hal.archives-ouvertes.fr/halshs-00879447
An adaptive large neighborhood search heuristic for two-echelon vehicle routing problems arising in city logistics, Computers & Operations Research, vol.39, issue.12, pp.3215-3228, 2012. ,
Subset-Row Inequalities Applied to the Vehicle-Routing Problem with Time Windows, Operations Research, vol.56, issue.2, pp.497-511, 2008. ,
A Branch-and-Cut Algorithm for the Symmetric Two-Echelon Capacitated Vehicle Routing Problem, Transportation Science, vol.47, issue.1, pp.23-37, 2013. ,
A branch and bound algorithm for the capacitated vehicle routing problem, Operations-Research-Spektrum, vol.5, issue.2, pp.77-85, 1983. ,
Projection results for vehicle routing, Mathematical Programming, vol.105, issue.2, pp.251-274, 2006. ,
The pyramidal capacitated vehicle routing problem, European Journal of Operational Research, vol.205, issue.1, pp.59-64, 2010. ,
A new branch-and-cut algorithm for the capacitated vehicle routing problem, Mathematical Programming, vol.100, issue.2, pp.423-445, 2004. ,
Improved branch-cut-and-price for capacitated vehicle routing, Mathematical Programming Computation, vol.9, issue.1, pp.61-100, 2016. ,
Limited memory Rank-1 Cuts for Vehicle Routing Problems, Operations Research Letters, vol.45, issue.3, pp.206-209, 2017. ,
The Two-Echelon Capacitated Vehicle Routing Problem: Models and Math-Based Heuristics, Transportation Science, vol.45, issue.3, pp.364-380, 2011. ,
Robust Branch-Cut-and-Price Algorithms for Vehicle Routing Problems, Operations Research/Computer Science Interfaces, vol.43, pp.297-325 ,
