Manufacturing at double the speed, Mat. Process. Technol, vol.229, pp.729-757, 2015. ,
Artificial intelligence in science of measurements: From measurement instruments to perceptive agencies, IEEE Trans. Instr. Meas, vol.52, pp.716-723, 2003. ,
Modulation transfer function in optical and electro-optical systems, 2011. ,
Advances in engineered surfaces for functional performance, Ann. CIRP, vol.57, pp.750-769, 2008. ,
Measurement of steep surfaces using white light interferometry, Strain, vol.4, pp.69-78, 2009. ,
High-precision lateral distortion measurement and correction in coherence scanning interferometry using an arbitrary surface, Opt. Express, vol.25, pp.18703-18712, 2017. ,
Review of in-situ monitoring and in-situ metrology for metal additive manufacturing, Materials & Design, vol.95, pp.431-445, 2016. ,
Manufacturing and measurement of freeform optics, Ann. CIRP, vol.62, pp.823-846, 2013. ,
Surface measurement errors using commercial scanning white light interferometers, Meas. Sci. Technol, vol.19, p.15303, 2008. ,
Characterization of typical surface effects in additive manufacturing with confocal microscopy, Surf. Topog.: Metrol. Prop, vol.3, p.14001, 2015. ,
Single-shot low coherence pointwise measuring interferometer with potential for in-line inspection, Meas. Sci. Technol, vol.28, p.25009, 2016. ,
Handbook of optical dimensional metrology, 2013. ,
Areal texture and angle measurements of tilted surfaces using focus variation methods, Proc. 3rd Int. Conf. Surface Metrology, pp.85-89, 2012. ,
Fast surface measurement using wavelength scanning interferometry with compensation of environmental noise, Appl. Opt, vol.15, pp.2903-2909, 2010. ,
Scaled topometry in a multisensor approach, Opt. Eng, vol.43, pp.2469-2477, 2004. ,
Detecting surface roughness on SLS parts with various measuring techniques, Polymer Testing, vol.53, pp.217-226, 2016. ,
Optical measurement of surface topography, 2011. ,
Metrology challenges for highly parallel micro-manufacture, Proc. 4M, pp.25-28, 2013. ,
Open questions is surface topography measurement: a roadmap, Surf. Topog.: Metrol. Prop, vol.3, p.13001, 2014. ,
Applications of super-resolution imaging in the field of surface topography measurement, Surf. Topogr. Metrol. Prop, vol.2, p.123001, 2014. ,
Signal formation in depth-scanning 3D interference microscopy at high numerical apertures, Proc. SPIE, vol.9660, pp.966015-966015, 2015. ,
Scatterometry -fast and robust measurements of nano-textured surfaces, Surf. Topogr. Metrol. Prop, vol.4, p.23003, 2016. ,
Bio-inspired functional surfaces for advanced applications, Ann. CIRP, vol.62, pp.607-628, 2013. ,
Recent trends in surface metrology, Wear, vol.271, pp.494-508, 2011. ,
Focus variation microscope: Linear theory and surface tilt sensitivity, Appl. Opt, vol.55, pp.3555-3565, 2016. ,
Effect of matte coating on 3D optical measurement accuracy, Opt. Materials, vol.40, pp.1-9, 2015. ,
Predictive data analytics and machine learning enabling metrology and process control for advanced node IC fabrication, IEEE Advanced Semiconductor Manufacturing Conference, pp.313-319, 2015. ,
Verification of micro-scale photogrammetry for smooth three-dimensional object measurement, Meas. Sci. Technol, vol.28, p.55010, 2017. ,
Combined use of a priori data for fast system self-calibration of a non-rigid multi-camera fringe projection system, Proc. SPIE 1033, pp.1033006-1033007, 2017. ,
A flexible decoupled camera and projector fringe projection system using inertial sensors, Opt. Eng, vol.56, p.104106, 2017. ,
Opportunities of sustainable manufacturing in Industry 4.0, Proc. CIRP, vol.40, pp.536-541, 2016. ,
On tilt and curvature dependent errors and the calibration of coherence scanning interferometers, Opt. Express, vol.25, pp.3297-3310, 2017. ,
Design and analysis of strut-based lattice structures for vibration isolation. Precision Engineering, 2017. ,
Roughness and function, Surf. Topogr. Metrol. Prop, vol.2, p.14001, 2013. ,
Surface texture measurement and characterisation for additive manufacturing, Precision Engineering, vol.46, pp.34-47, 2016. ,
Real-time structured light profilometry: a review, Opt. Lasers Eng, vol.87, pp.18-31, 2016. ,
Intelligent sampling for the measurement of structured surfaces, Meas. Sci. Technol, vol.23, p.85006, 2012. ,
Review of the data fusion techniques in surface metrology, Surf. Topogr. Metrol. Prop, vol.3, p.23001, 2015. ,
Multisensor data fusion in dimensional metrology, Ann. CIRP, vol.58, pp.701-721, 2009. ,
Adaptive sampling method for the inspection planning on CMM for free-form surfaces, Int. J. Manuf. Technol, vol.67, 1967. ,
Review of single-shot 3D shape measurement by phase calculation-based fringe projection techniques, Opt. Lasers Eng, vol.50, pp.1097-1106, 2012. ,
Temporal phase unwrapping algorithms for fringe projection profilometry: a comparative review, Opt. Lasers Eng, vol.85, pp.84-103, 2016. ,
