Precision Assembly of Optical Backplanes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Full optical backplanes can be seen as a promising technology for high bandwidth ICT (Information and Communication Technology) apparatuses and high performance computing systems. According to a recent frame-based solution, the backplane mounts a number of independent optical interconnect circuits mainly consisting of a set of optical fiber ribbons of different lengths arranged to fulfill a specific planar ribbon routing. A non-negligible problem is related to the development of suitable techniques for the efficient and cost-effective assembly of such sub-circuits. New systems are required that combine ultimate hardware and software capabilities and derive from a synergic implementation of digital and advanced manufacturing technologies. The successful assembly of the optical interconnection circuits lies in the development of cyber-physical production systems within the framework of Industry 4.0. In this context, this work will present and discuss how different innovative technologies and consolidated technologies applied in a novel context were exploited to demonstrate the feasibility of the automated backplane assembly. The achieved results are discussed in terms of design of the work-cell layout and related equipment, simulation tests, tool path planning, and final task execution.
478022_1_En_11_Chapter.pdf (373.69 Ko) Télécharger le fichier
hal-02115844 , version 1 (30-04-2019)
Paternité
Serena Ruggeri, Gianmauro Fontana, Irene Fassi. Precision Assembly of Optical Backplanes. 8th International Precision Assembly Seminar (IPAS), Jan 2018, Chamonix, France. pp.114-123, ⟨10.1007/978-3-030-05931-6_11⟩. ⟨hal-02115844⟩
50 Consultations
22 Téléchargements
