Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
1Professorship of Machine Tool Design and Forming Technology (Technische Universität Chemnitz
Institut für Werkzeugmaschinen und Produktionsprozesse
Professur für Werkzeugmaschinenkonstruktion und Umformtechnik
D-09107 Chemnitz - Germany)
Abstract : In order to realize resource-efficient products and manufacturing processes, lightweight construction solutions have become enormously significant in many areas. Generally, material savings are always done at the expense of rigidity. However, additional weight can be saved through functional integration. One possibility is given by the functional material piezoceramic. This material can be used as sensor or actuator. A new approach for the structural integration of piezoceramic in sheet metals is with the technique joining by forming. Therefore, PZT fibers are assembled in a local microstructure of a sheet metal, which is followed by the joining operation. The article is a contribution to transfer this approach into a high-volume production process, which is necessary for the industrial area to take root. Manufacturing processes for PZT fiber arrays with minimal manufacturing tolerances are presented. The process of stacking PZT plates with distance elements and subsequent dicing into slices is shown as a suitable variant. Furthermore, an automated assembly system is tested with regard to the measuring technology. A machine vision and a chromatic confocal sensor are compared in the assembly system. The results show that the machine vision system is better suited for pose measurement of the PZT fiber arrays and the chromatic confocal sensor achieves better results for the microstructured sheet metals.
https://hal.inria.fr/hal-02115854 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, April 30, 2019 - 3:12:47 PM Last modification on : Tuesday, December 7, 2021 - 1:10:02 PM
Marek Schmidt, Volker Wittsock. Prefabrication and Automated Micro Assembly of Piezoceramic Fiber Array Transducers in Microstructured Surfaces of Sheet Metals. 8th International Precision Assembly Seminar (IPAS), Jan 2018, Chamonix, France. pp.124-133, ⟨10.1007/978-3-030-05931-6_12⟩. ⟨hal-02115854⟩
