Processing Fuzzy Relational Queries Using Fuzzy Views
This paper proposes two original approaches to the processing of fuzzy queries in a relational database context. The general idea is to use views, either materialized or not. In the first case, materialized views are used to store the satisfaction degrees related to user-defined fuzzy predicates, instead of calculating them at runtime by means of user functions embedded in the query (which induces an important overhead). In the second case, abstract views are used to efficiently access the tuples that belong to the α-cut of the query result, by means of a derived Boolean selection condition.
