Mobility Enhancement Technology for Scaling of CMOS Devices: Overview and Status, Journal of Electronic Materials, vol.40, issue.7, pp.1584-1612, 2011. ,
Physics of strain effects in semiconductors and metal-oxide-semiconductor field-effect transistors, Journal of Applied Physics, vol.101, issue.10, p.104503, 2007. ,
Enhancing CMOS transistor performance using lattice-mismatched materials in source/drain regions, Semiconductor Science and Technology, vol.22, issue.1, pp.S177-S182, 2006. ,
Characterization of Stress Transfer from Process Induced Stressor Layer to Substrate in MOSFETs, ECS Transactions, vol.50, issue.4, pp.241-248, 2013. ,
14nm FDSOI upgraded device performance for ultra-low voltage operation, 2015 Symposium on VLSI Technology (VLSI Technology), pp.168-169, 2015. ,
A Novel Fabrication Technique of Ultrathin and Relaxed SiGe Buffer Layers with High Ge Fraction for Sub-100 nm Strained Silicon-on-Insulator MOSFETs, Japanese Journal of Applied Physics, vol.40, issue.Part 1, No. 4B, pp.2866-2874, 2001. ,
High-mobility strained SiGe-on-insulator pMOSFETs with Ge-rich surface channels fabricated by local condensation technique, IEEE Electron Device Letters, vol.26, issue.4, pp.243-245, 2005. ,
Kinetics and mechanism of oxidation of SiGe: dry versus wet oxidation, Applied Physics Letters, vol.54, issue.7, pp.644-646, 1989. ,
Stacking fault generation during relaxation of silicon germanium on insulator layers obtained by the Ge condensation technique, Applied Physics Letters, vol.90, issue.7, p.074101, 2007. ,
Comprehensive Study of the Fabrication of SGOI Substrates by the Ge Condensation Technique: Oxidation Kinetics and Relaxation Mechanism, ECS Transactions, vol.25, issue.7, pp.363-375, 2019. ,
Strain/composition interplay in thin SiGe layers on insulator processed by Ge condensation, Materials Science in Semiconductor Processing, vol.42, pp.251-254, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01707172
Nano-structuring in SiGe by oxidation induced anisotropic Ge self-organization, Journal of Applied Physics, vol.113, issue.10, p.104310, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01811409
A comparison of the mechanical stability of silicon nitride films deposited with various techniques, Applied Surface Science, vol.260, pp.69-72, 2012. ,
Shallow Trench Isolation for the 45-nm CMOS Node and Geometry Dependence of STI Stress on CMOS Device Performance, IEEE Transactions on Semiconductor Manufacturing, vol.20, issue.2, pp.59-67, 2007. ,
Nanoscale holographic interferometry for strain measurements in electronic devices, Nature, vol.453, issue.7198, pp.1086-1089, 2008. ,
Off-Axial Aberration Correction using a B-COR for Lorentz and HREM Modes, Microscopy and Microanalysis, vol.20, issue.S3, pp.932-933, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01430589
Aplanatic imaging systems for the transmission electron microscope, Nuclear Instruments and Methods in Physics Research Section A: Accelerators, Spectrometers, Detectors and Associated Equipment, vol.645, issue.1, pp.20-27, 2011. ,
Double-biprism electron interferometry, Applied Physics Letters, vol.84, issue.17, pp.3229-3231, 2004. ,
Mapping 2D strain components from STEM moiré fringes, HoloDark Phase (HREM Research, pp.515-516, 2016. ,
Accurate control of the misorientation angles in direct wafer bonding, Applied Physics Letters, vol.80, issue.5, pp.793-795, 2002. ,
Introduction to Focused Ion Beams, Introduction to Focused Ion Beams: Instrumentation, Theory, Techniques and Practice, 2005. ,
Young's Modulus, Shear Modulus, and Poisson's Ratio in Silicon and Germanium, Journal of Applied Physics, vol.36, issue.1, pp.153-156, 1965. ,
Viscous flow of thermal SiO2, Applied Physics Letters, vol.30, issue.6, pp.290-293, 1977. ,
A Viscous Flow Model to Explain the Appearance of High Density Thermal SiO2 at Low Oxidation Temperatures, Journal of The Electrochemical Society, vol.129, issue.11, pp.2594-2597, 1982. ,
Lattice Parameter and Density in Germanium-Silicon Alloys1, The Journal of Physical Chemistry, vol.68, issue.10, pp.3021-3027, 1964. ,
Elasticity, 2010. ,
Déformations introduites lors de la fabrication de transistors FDSOI : Une contribution de l'holographie électronique en champ sombre, 2016. ,
Strain, stress, and mechanical relaxation in fin-patterned Si/SiGe multilayers for sub-7 nm nanosheet gate-all-around device technology, Applied Physics Letters, vol.112, issue.5, p.051901, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-02071864
, Appl. Phys. Lett, vol.112, p.51901, 2018.
Mechanical simulations of BOX creep for strained FDSOI, 2017 Joint International EUROSOI Workshop and International Conference on Ultimate Integration on Silicon (EUROSOI-ULIS), pp.91-94, 2017. ,
