LMF Reloaded - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
LMF Reloaded
Lexical Markup Framework (LMF) or ISO 24613 [1] is a de jure standard that provides a framework for modelling and encoding lexical information in retrodigitised print dictionaries and NLP lexical databases. An in-depth review is currently underway within the standardisation subcommittee , ISO-TC37/SC4/WG4, to find a more modular, flexible and durable follow up to the original LMF standard published in 2008. In this paper we will present some of the major improvements which have so far been implemented in the new version of LMF.
AsiaLex2019_paper_74-5.pdf (619.58 Ko) Télécharger le fichier
hal-02118319 , version 1 (23-05-2019)
Laurent Romary, Mohamed Khemakhem, Fahad Khan, Jack Bowers, Nicoletta Calzolari, et al.. LMF Reloaded. AsiaLex 2019: Past, Present and Future, Jun 2019, Istanbul, Turkey. ⟨hal-02118319⟩
259 Consultations
181 Téléchargements
