A global approach to fiber nD architectures and self-sealing matrices: from research to production, Int. J. Appl. Ceram. Technol, vol.2, p.97, 2005. ,
Composites in aerospace industry, Adv. Sci. Technol, vol.50, pp.153-162, 2006. ,
Modelling of the mechanical behavior and damage processes of fibrous ceramic matrix composites: application to a 2-d sic/sic, International Journal of Solids and Structures, vol.37, issue.6, pp.919-942, 2000. ,
Matériau composite protégé contre l'oxydation par une matrice autocicatrisante et son procédé de fabrication (composite material protected from oxidation by a self-healing matrix, and method for making same, 1995. ,
Fatigue behaviour at high temperature in air of a 2d sic/sib-c composite with a self-healing multilayered matrix, Ceramic Transactions, vol.128, pp.127-141, 2001. ,
Selfhealing mechanisms of a S iC fiber reinforced multilayered ceramic matrix, J. Eur. Ceram. Soc, vol.27, issue.4, pp.2085-2094, 2007. ,
Fatigue statique de monofilaments et de fils sic hi-nicalonànicalon`nicalonà 500 ? c et 800 ? c, Revue des Composites et des Matériaux Avancés, vol.16, issue.2, pp.221-241, 2006. ,
A new approach to the subcritical cracking of ceramic fibers, Composites Science and Technology, vol.70, issue.11, pp.1575-1583, 2010. ,
Mechanical behaviour and lifetime modelling of self-healing ceramic-matrix composites subjected to thermomechanical loading in air, Composites Part A: Applied Science and Manufacturing, vol.40, issue.8, pp.976-984, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00435883
Prediction of the lifetime of self-healing ceramic matrix composites: applications to structural computations, Procs 7 th International Conference on High Temperature Ceramic Matrix Composites (HT-CMC7) ,
, , pp.194-202, 2010.
Original 1d oxidation modeling of composites with complex architectures, Procs. 5 th Conf. on High Temperature Ceramic Matrix Composites (HT-CMC 5), pp.315-320, 2005. ,
A micromechanics-based approach to the mechanical behavior of brittle-matrix composites, vol.61, pp.2259-2272, 2001. ,
Two-dimensional oxydation modelling of MAC composite materials, INRIA, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00526121
Kinetics and mechanisms of oxidation of 2d woven c/sic composites: I, experimental approach, Journal of the American Ceramic Society, vol.77, issue.8, pp.2049-2057, 1994. ,
Fundamental and practical aspects of the chemical vapor infiltration of porous substrates, th Intl. Conf. on High TemperatureChemistry of Inorganic Materials.NIST, vol.27, pp.221-235, 1989. ,
Vapor-phase fabrication and properties of continuous-filament ceramic composites, Science, vol.253, pp.1104-1109, 1991. ,
Modelling of the CVI processes, Adv. Sci. Technol, vol.50, pp.97-106, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01895878
Damage and failure in ceramic matrix minicomposites: Experimental study and model, Acta Materialia, vol.45, issue.3, pp.1025-1044, 1997. ,
Approach to Microstructure-Behavior Relationships for Ceramic Matrix Composites Reinforced by Continuous Fibers, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01695799
In situ X-ray microtomography characterization of damage in S iC f /S iC minicomposites, Composites Science and Technology, vol.71, issue.6, pp.916-924, 2011. ,
Application of X-ray computed micro-tomography to the study of damage and oxidation kinetics of thermostructural composites, Nuclear Instruments and Methods in Physics Research B, vol.324, pp.113-117, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01538029
High temperature behavior of ceramic matrix composites with a self healing matrix, Repairing Structures using Composite Wraps: Procs. 8 th Japanese/European Symposium on Composite Materials, 2003, vol.8, pp.159-170, 2002. ,
Delayed failure at intermediate temperatures (600 ? -700 ? C) in air in silicon carbide multifilament tows, J. Amer. Ceram. Soc, vol.87, issue.5, pp.888-893, 2004. ,
Delayed failure of Hi-Nicalon and Hi-Nicalon S multifilament tows and single filaments at intermediate temperatures (500 ? -800 ? C), Journal of the American Ceramic Society, vol.92, issue.3, pp.702-709, 2009. ,
Oxidation of silicon carbide fibers during static fatigue in air at intermediate temperatures, Journal of the American Ceramic Society, vol.92, issue.9, pp.2067-2073, 2009. ,
Advances in self-healing ceramic matrix composites, vol.16, pp.369-409, 2014. ,
, Structure and oxidation of C/C composites: role of the interface, vol.39, pp.971-984, 2001.
Overview on the Self-Sealing Process in the SiC f, Design, Development, and Applications of Engineering Ceramics and Composites, vol.215 ,
Oxidation behavior of boron carbide (B 4 C) in a complex atmosphere N 2 /O 2 H 2 O, High temperature corrosion and materials chemistry IV, pp.339-350, 2003. ,
Oxidation mechanisms and kinetics of SiC-matrix composites and their constituents, J. Mater. Sci, vol.39, issue.24, pp.7303-7316, 2004. ,
Scale Approach of Degradation Mechanisms inside a SiC(f)/Si-B-C(m) Based Self-Healing Matrix Composite in a Dry Oxidizing Environment, Oxidation of Metals, vol.80, pp.279-287, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01629901
Imagebased 2D numerical modeling of oxide formation in self-healing CMCs, Developments in Strategic Materials and Computational Design III, vol.33, pp.117-125, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00653353
General relationship for the thermal oxidation of silicon, J. Appl. Phys, vol.36, issue.2, pp.3770-3778, 1965. ,
, Mumps: Multifrontal massively parallel sparse direct solver, 2018.
, The Properties of Gases and Liquids, 1987.
Kinetic oxidation laws of boron carbide in dry and wet environments, High temperature ceramic matrix composites 5, pp.321-326, 2005. ,
Acoustic emission and electrical resistance in SiC-based laminate ceramic composites tested under tensile loading, Journal of the European Ceramic Society, vol.37, issue.13, pp.3861-3872, 2017. ,
