High-Availability algorithms for distributed stream processing, Proc. of the 21st International Conference on Data Engineering, pp.779-790, 2005. ,
Integrating scale out and fault tolerance in stream processing using operator state management, Proc. of the 2013 ACM SIGMOD International Conference on Management of Data, pp.725-736, 2013. ,
A taxonomy and performance model of data skew effects in parallel joins, Proc. of the 17th International Conference on Very Large Data Bases, pp.537-548, 1991. ,
, Scalable and Adaptive Online Joins. In: the VLDB Endowmen, vol.7, pp.441-452, 2014.
, Scalable Distributed Stream Join Processing In: ACM SIGMOD International Conference on Management of Data, pp.811-825, 2015.
Load balancing and skew resilience for parallel joins, IEEE International Conference on Data Engineering, pp.313-324, 2016. ,
, Cost-Effective Stream Join Algorithm on Cloud System In: the 25th ACM International on Conference on Information and Knowledge Management, pp.1773-1782, 2016.
An Efficient Approximation Scheme for the OneDimensional Bin-Packing Problem In: 23rd Annual Symposium on Foundations of Computer Science, pp.312-320, 1982. ,
Parallel Stream Processing Against Workload Skewness and Variance, 2016. ,
, ACM SIGMOD International Conference on Management of Data, p.11, 2014.
, Memory Throughput I/O for Cluster Computing Frameworks In: LADIS, 2013.
Optimal Operator State Migration for Elastic Data Stream Processing, HAL -INRIA, vol.22, issue.3, p.14, 2013. ,
