Research of Port Competitiveness Evaluation Based on Attribute Evaluation Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Xueyan Duan
  • Fonction : Auteur
  • PersonId : 1033414
Jieqiong Liu
  • Fonction : Auteur
  • PersonId : 1046599
Attribute Evaluation Method can simulate the psychological preferences of decision makers and give the evaluation results in line with the psychology of decision makers. The effectiveness of this method is verified through the ranking of 11 ports’ competitiveness, which also provides a new idea for port competitiveness evaluation.
474230_1_En_9_Chapter.pdf (134.28 Ko) Télécharger le fichier
hal-02118801 , version 1 (03-05-2019)
Paternité
Xueyan Duan, Jieqiong Liu. Research of Port Competitiveness Evaluation Based on Attribute Evaluation Method. 2nd International Conference on Intelligence Science (ICIS), Nov 2018, Beijing, China. pp.81-87, ⟨10.1007/978-3-030-01313-4_9⟩. ⟨hal-02118801⟩
60 Consultations
19 Téléchargements
