How to Do Knowledge Module Finishing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Shunpeng Zou
  • Fonction : Auteur
  • PersonId : 1046615
Xiaoqun Wang
  • Fonction : Auteur
  • PersonId : 1046616
The aim is to introduce a simple and unique tool to realize the ergonomics of man-machine collaborative research on “governance of the country”. This method: First, the original text is imported, and then, a Chinese character board is generated, and then the language points, knowledge points, and original points are matched. The feature is human-machine collaboration. The result is that the Chinese character is tessellated, the Chinese chess spectrum is made, and the original chess is played. The knowledge module can be used for finishing. Its significance is: the language board, the knowledge game, and the original board game are digital, structured, and formal indirect ways to achieve automatic calculation: language points, knowledge points, and original points. The five menu-based knowledge modules of this example can be layered and distributed, and at least sixteen knowledge modules can be finished. Man-machine can be repeated calls. This is a contribution to the interpretation or understanding of texts.
474230_1_En_14_Chapter.pdf (630.37 Ko) Télécharger le fichier
hal-02118808 , version 1 (03-05-2019)
Paternité
Shunpeng Zou, Xiaohui Zou, Xiaoqun Wang. How to Do Knowledge Module Finishing. 2nd International Conference on Intelligence Science (ICIS), Nov 2018, Beijing, China. pp.134-145, ⟨10.1007/978-3-030-01313-4_14⟩. ⟨hal-02118808⟩
27 Consultations
49 Téléchargements
